2018-07-09, 17:40
(2018-07-09, 04:31)bluenote Wrote: [ -> ]Wow, when you have problems, you realize how bad logitech and harmony are with their software.Did you determine if you have an eHome receiver or a generic USB device? The two devices listed in this guide have the largest number of commands. What exactly are you missing?
Can anyone tell me the database entry for the largest list of MCE/microsoft codes? Every device I try seems to have limitations about what codes are built in. And unfortunately it seems myharmony doesn't allow buttons from other devices to be configured under a device, AND I've got a bunch of broken 67x's I don't feel like trying to configure to learn. It would be nice if they would fix this stuff, you know?
Anyways, sorry for the griping. Can anyone recommend what is the widest selection of Windows remote codes and what database entry it is?
(Not being able to search or select from a list in the myharmony, or anywhere, deserves a special place in hell..)
thanks for any advice
