hi
I have upgraded to Isengard ~4 times now, and I keep having this issue with the skin. I hope you can help
Every time I upgrade, after I reboot, everything works as expected. I have a full screen video,no issues.
The next time I play a video, I have to manually bring up the player from the context screen, it refuses to do it on its own.
Edit to clairfy: If I click on a video in Youtube for instance, the video starts to play so the audio is going, but the focus stays on the search list. I have to bring up the context menus which gives me options like List:, SortBy, Descending, Search,Player
and then click Player to see video
Has anyone else reported this? I tried searching, but came up with no relevant results.
kodi.log here
http://pastebin.com/gjS79RJn
any help would be nice,
if i revert the whole system back to Helix or Gotham, the issue is not present. (i have the same issue if i am running the Helix skin in Isengard, and the mouse pointer is really small, not normal)
BTW, I just realized,I never tested this on the default skin since I have been using Sio2X for at least 1 + year now and never use confluence
EDIT: running osmc (Debian based obviously) on raspberrypi 2,
Edit 2: I have now tried the osmc skin, and confluence, neither exhibit this issue,
osmc@osmc:~/.kodi/addons/skin.sio2x-isengard$ head changelog.txt
3.5.5
* Isengard
3.1.6
* Spanish Localization by Blas Ortega PeƱas
* Fix for time being wrong color in fullscreen infos
* Unwatched Episodes for sio2-x view
edit 3:
a new log
http://pastebin.com/0vNYj8qZ
I noticed this,
osmc@osmc:~$ cat .kodi/temp/kodi.log | grep "Display resolution"
12:57:38 144.783554 T:1163916320 NOTICE: Display resolution ADJUST : 1280x720 (1280x720) @ 59.94 - Full Screen (21) (weight: 0.000)
12:57:57 163.332123 T:1163916320 NOTICE: Display resolution ADJUST : 1280x720 (1280x720) @ 50.00 - Full Screen (25) (weight: 0.000)
12:58:06 172.456635 T:1155527712 NOTICE: Display resolution ADJUST : 1280x720 (1280x720) @ 59.94 - Full Screen (21) (weight: 0.000)
osmc@osmc:~$
On this set,
Full Screen (21) always played fine,
Full Screen (25) does not
edit 4:
I played the same video as before, (which gave Full Screen (21))
It did not open in full screen this time
this is the rest of the log, for this session
e
http://pastebin.com/QMHZR3mG
(sorry for the log paste)
