Full Version: Help with correcting video size
So when I go onto my andriod box the screen is fine, but when I play a movie in xbmc the screen only shows the top right corner of the movie how do I fix? It's only showing 1/4 of the screen and even when I change the display settings it still only shows that top right corner of the movie stretched across the full screen
Please help
try clicking the back slash " \ " on key board. also the "z" is shortcut for screen size. try the " \" first if that fails try the "z" . That's the best I got but I'm a novice, so good luck.
I'm having the same issue.
I tried back slash key and the Z key without success.
Any ideas?
Found the solution for my issue. In your Android box settings, under 'Display', select 720p for default video resolution. Do not use auto detect.
HELP!!!!!
I bought a Genaitech 1800 for my GF. She is frustrated because of the screen size on playback. I have tried the manual setting to 720p but it keeps going back to 1080p.
My tv is 720p LG....
Any suggestions?
Please??
