2015-03-10, 13:57
Hi there, I'm currently in the process of (re)building my living room setup but unfortunately my current HTPC case is too big for where it needs to go.
I've looked all over for a decent one but none seem to meet all my needs, they tend to be lacking one or two things.
Requirements:
MAX size: W46cm / H13cm / D35cm (I know that's a decent size but that's the size of the space it needs to go. obviously the smaller the better for airflow.)
Now here's the part i'm struggling with:
Must support low profile graphics card (for HDMI output)
External 5.25 Drive bay or built in IR sensor (i already have a 5.25 iMon display and receiver but i'm not fussed about the display. IR sensor is obviously a must)
The HTPC has mixed use as mainly Kodi but also gaming (running Win7) so don't really want to downgrade. I have all the components. Just need the right case.
For reference i'm currently using a SilverStone MILO ML03 Case But it's an extremely tight fit with no airflow.
Thanks in advance for any suggestions.
Requirements:
