(2015-10-15, 08:04)Tgxcorporation Wrote: [ -> ] (2015-10-15, 00:11)mrfatboy Wrote: [ -> ]Hi TGX,
I recently had to do a complete re-install of Windows 7. I am in the process of re-installing Kodi 15.1 and your Nebula skin. Of course I have done many customizations over the years and it's been hard trying to figure out how I did them.
How do you complete remove the sub menus from the Home screen? I can't find it in the settings and I can't remember if I changed the code.
There no setting to disable submenus. You need to edit the file "Includes_Horizontal_Home.xml":
https://github.com/Tgxcorporation/skin.n...e.xml#L418
and remove the code from line 418 to 442.
Tgx
Thanks that worked. I don't remember doing that but I must have. It's been 5 years with many upgrades and skins. By chance could another skin have the option to remove and I then installed nebula? I'm just curious.
Hey. I have a problem with the cover flow view. At movies and tv shows it show on some entries the thumb and not the posters. I use kodi 15.2 it works on other skins.
Image:
http://fs.ilold.de/images/102115225705.png
I've realized that the films that are incorrectly displayed have a thumb in the folder.
(2015-10-21, 22:54)caidoo Wrote: [ -> ]Hey. I have a problem with the cover flow view. At movies and tv shows it show on some entries the thumb and not the posters. I use kodi 15.2 it works on other skins.
Image: http://fs.ilold.de/images/102115225705.png
Can you please post a screenshot of your folder with thumb and film files?
Tgx
It's now fixed in the latest release on Github:
https://github.com/Tgxcorporation/skin.n...5b6b38eb8f
You can apply the same changes to your Includes_Variables.xml file or download and replace it from Github.
Tgx
Thanks, works now perfectly, and yes it was on both, love this skin.
Hi, there is this bug with Nebula skin that when I am browsing the apps in Programs or browsing video add-ons or browsing movie titles in some video add-on it switches from the "Icons" view to the default "Large List" view by itself!! And I have to change the view back to "Icons" again but it would switch back randomly to the Large list view on it own which is very annoying. I tried other Kodi skins and they don't have this issue. Anyways, I created a debug report for you. Hopefully, you'd fix this minor but annoying bug. Thanks
http://xbmclogs.com/p32ftksvq
I may have fixed it myself. I went to Nebula's skin setting...Art Management..and disabled "Enable Extra Fanart".
It's not changing the view anymore
I'll report back if it happens again.
(2015-11-04, 04:06)Babak678 Wrote: [ -> ]I may have fixed it myself. I went to Nebula's skin setting...Art Management..and disabled "Enable Extra Fanart".
Yes, there are a lot of errors related to the missing extrafanart addon. It could be that. I remember the same issue with this plugin fixed disabling it in skin settings.
Tgx
I just discovered this Skin and I am quite impressed. Unfortunately I cannot seem to get the cover overlay icons for VideoExtras Add-On to work. I was led to believe they were supposed to be working - am I mistaken? Thanks in advance for any hints!
Hello! First of all your Nebula skin is really good and one of the best by union of style and usability - great job! Also top panel player and controls is very useful!
But, please, make setting to dont zoom selected line of files list, because at my 1366x768 TV with zoomed line there are only 3 lines remain! Its too few for comfortable control of big lists, also this zoom does not have any functionality at files lists, album art is better to place at static position. At addons-skins lists there are yet less rows - only 2 rows!
Also Back control of menus by mouse move to left side of screen is really enjoyable, exept that TV is second display of my HTPC at right position, so at TVs left side mouse cursor just move to primary monitor desktop. Add setting to disable it.
Great Skin! i'm spent the day setting everything up just the way I like after installing on FTV. Quick question - when i am editing the home screen menu's i can't seem to change the thumbnails on the actual menu items. The ones that come pre-installed aren't always populating (some just use the default thumbnail) and if i create my own menu item then i can't change it from default. When i try to change the thumbnail instead of bringing me to the folder options to select pictures (like it does in the background setting) it just brings 2 repo's up.
Any help would be appreciated.
Thanks,
Jucman
(2015-12-06, 03:54)jucman Wrote: [ -> ]Great Skin! i'm spent the day setting everything up just the way I like after installing on FTV. Quick question - when i am editing the home screen menu's i can't seem to change the thumbnails on the actual menu items. The ones that come pre-installed aren't always populating (some just use the default thumbnail) and if i create my own menu item then i can't change it from default. When i try to change the thumbnail instead of bringing me to the folder options to select pictures (like it does in the background setting) it just brings 2 repo's up.
Thanks,
Jucman
Please have a look at the wiki:
https://github.com/Tgxcorporation/skin.n...enu-Editor
Especially the part:
https://github.com/Tgxcorporation/skin.n...leshooting
Tgx
