Full Version: Any suggestion on my Media Updater for Slideshow?
Hello, I would like to know if there is some leak or error in my simple Media Updater for Slideshow service add-on.
This addon checks for new file changes in the media folder every 2 minutes, and reloads the Slideshow in that case.
import time
import xbmc
import subprocess
import re
from os import listdir
minutos = 2
mediafolder = "/storage/pictures"
logfolder = "/storage/.kodi/temp/"
templist = listdir(mediafolder)
if __name__ == '__main__':
    monitor = xbmc.Monitor()
    while True:
        if monitor.waitForAbort(minutos * 60):
            # kodi turned off
            break
        # debug
        f = open(logfolder + 'actualizar-slideshow.log', 'a')
        # read dir
        newlist = listdir(mediafolder)
        # if there are changes
        if (templist != newlist):
            # build regex with list of new files
            diff = set(newlist) ^ set(templist)
            regex = ('|').join( [ re.escape(item) for item in diff ] )
            # check if there are files transferring
            try:
                # if grep returns 0, there are actually files transferring
                subprocess.check_output('lsof | grep -E "' + regex + '"', shell=True)
                f.write('%s: cambios \n' % time.ctime())
                f.write('%s \n' % list(diff))
                f.close()
                # go to the first line in "while True" statement
                continue
            except:
                # grep returns 1, there are no files transferring
                pass
            # refresh slideshow (the dirty way, because XMBC.Slideshow() doesn't support video yet.)
            xbmc.executebuiltin('XBMC.ActivateWindow(Pictures,' + mediafolder + ')')
            xbmc.executebuiltin('XBMC.Action(Play)')
            # save new list into temp list
            templist = newlist
            f.write('%s: actualizado\n' % time.ctime())
        else:
            f.write('%s: todo igual\n' % time.ctime())
        f.close()
Here's with spanish comments,
import time
import xbmc
import subprocess
import re
minutos = 2
    while True:
            # se apaga el kodi, nos vimo
            break
        # debug
        # leo
        # si hay cambios
            # armo el regex con la lista de archivos nuevos
            # comprobar si hay archivos transfiriendo
            try:
                # si grep retorna 0, hay archivos transfiriendo
                f.close()
                # VOY AL COMIENZO DEL WHILE
                continue
            except subprocess.CalledProcessError:
                # grep retorna 1, no encontro archivos transfiriendo
                pass
            # refrescar la presentacion (provisorio)
            # guardo
            templist = newlist
        else:
        f.close()
