Ok, here goes. The first video played is an mkv file with untouched video and audio from blu ray (plays flawlessly with vaapi), the second video is a blu ray file untouched (again plays flawlessly with vaapi). However, the third file to show you my problem is a 1080p web download (frame rate jumps and is unwatchable with vaapi enabled). I don't understand as all files use x264. All files which are not full blu ray refuse to use the vaapi. Surely it can't be me. They all work fine with windows but linux kodi makes a difference between them.
The log requested is
http://xbmclogs.com/pmz8ekfsj
Please help as I don't wish to revert to windows. Surely this can be rectified.
ps if this helps :-
craigles@craigles-K52F:~$ vainfo
libva info: VA-API version 0.37.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_37
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.37 (libva 1.5.0)
vainfo: Driver version: Intel i965 driver for Intel® Ironlake Mobile - 1.5.0
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264Main : VAEntrypointVLD
VAProfileH264High : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
pps:- vlc plays all videos fine with vaapi so the problem must be with my set up of kodi.
