2015-03-12, 05:46
Here's my debug log. I hope to get this issue resolved asap.
22:38:27 T:636 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:38:27 T:636 NOTICE: -----------------------------------------------------------------------
22:38:27 T:636 NOTICE: Starting XBMC (13.2 Git:20140817-0f3db05). Platform: x86 Win32 32-bit
22:38:27 T:636 NOTICE: Using Release XBMC x32 build, compiled Aug 17 2014 by MSVC 160040219 for x86 Win32 32-bit version 0x06000000
22:38:27 T:636 NOTICE: Running on Windows 7 SP1 64-bit, build 7601
22:38:27 T:636 NOTICE: Host CPU: Intel(R) Core(TM) i3-2330M CPU @ 2.20GHz, 4 cores available
22:38:27 T:636 NOTICE: Desktop Resolution: 1366x768 32Bit at 60Hz
22:38:27 T:636 NOTICE: Running with restricted rights
22:38:27 T:636 NOTICE: Aero is disabled
22:38:27 T:636 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
22:38:27 T:636 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
22:38:27 T:636 NOTICE: special://masterprofile/ is mapped to: C:\Program Files (x86)\XBMC\portable_data\userdata
22:38:27 T:636 NOTICE: special://home/ is mapped to: C:\Program Files (x86)\XBMC\portable_data\
22:38:27 T:636 NOTICE: special://temp/ is mapped to: C:\Program Files (x86)\XBMC\portable_data\cache
22:38:27 T:636 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
22:38:27 T:636 NOTICE: Local hostname: TEPY-PC
22:38:27 T:636 NOTICE: Log File is located: C:\Program Files (x86)\XBMC\portable_data\xbmc.log
22:38:27 T:636 NOTICE: load settings...
22:38:27 T:636 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:38:27 T:636 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
22:38:27 T:636 NOTICE: Default DVD Player: dvdplayer
22:38:27 T:636 NOTICE: Default Video Player: dvdplayer
22:38:27 T:636 NOTICE: Default Audio Player: paplayer
22:38:27 T:636 NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:38:27 T:636 NOTICE: Log level changed to 0
22:38:27 T:636 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
22:38:27 T:636 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:38:27 T:636 NOTICE: Loaded playercorefactory configuration
22:38:27 T:636 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:38:27 T:636 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:38:27 T:4532 NOTICE: Thread ActiveAE start, auto delete: false
22:38:27 T:3412 NOTICE: Thread AESink start, auto delete: false
22:38:27 T:4532 NOTICE: Found 2 Lists of Devices
22:38:27 T:4532 NOTICE: Enumerated DIRECTSOUND devices:
22:38:27 T:4532 NOTICE: Device 1
22:38:27 T:4532 NOTICE: m_deviceName : {7292F059-70D7-4962-8AB2-771616EB4EA7}
22:38:27 T:4532 NOTICE: m_displayName : Speakers - Speakers (High Definition Audio Device)
22:38:27 T:4532 NOTICE: m_displayNameExtra: DIRECTSOUND: Speakers (High Definition Audio Device)
22:38:27 T:4532 NOTICE: m_deviceType : AE_DEVTYPE_PCM
22:38:27 T:4532 NOTICE: m_channels : FL,FR
22:38:27 T:4532 NOTICE: m_sampleRates : 44100
22:38:27 T:4532 NOTICE: m_dataFormats : AE_FMT_FLOAT
22:38:27 T:4532 NOTICE: Device 2
22:38:27 T:4532 NOTICE: m_deviceName : default
22:38:27 T:4532 NOTICE: m_displayName : default
22:38:27 T:4532 NOTICE: Enumerated WASAPI devices:
22:38:27 T:4532 NOTICE: m_displayNameExtra: WASAPI: Speakers (High Definition Audio Device)
22:38:27 T:4532 NOTICE: m_sampleRates : 192000,96000,48000,44100
22:38:27 T:4532 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
22:38:27 T:636 NOTICE: Running database version Addons16
22:38:27 T:636 NOTICE: ADDONS: Using repository repository.gomioa
22:38:27 T:636 NOTICE: ADDONS: Using repository repository.xbmc.org
22:38:27 T:636 NOTICE: ADDONS: Using repository repository.superrepo.org.gotham.programs
22:38:27 T:636 NOTICE: ADDONS: Using repository repository.lambda
22:38:27 T:636 NOTICE: ADDONS: Using repository repository.o9r1sh
22:38:27 T:636 NOTICE: ADDONS: Using repository repository.superrepo.org.gotham.repositories
22:38:27 T:636 NOTICE: ADDONS: Using repository repository.pvr-win32.xbmc.org
22:38:27 T:636 NOTICE: ADDONS: Using repository repository.superrepo.org.gotham.all
22:38:27 T:4252 NOTICE: Thread RemoteControl start, auto delete: false
22:38:27 T:3604 NOTICE: Thread PeripBusCEC start, auto delete: false
22:38:27 T:4848 NOTICE: Thread PeripBusUSB start, auto delete: false
22:38:27 T:636 NOTICE: Found screen: Generic PnP Monitor on Intel(R) HD Graphics Family, adapter 0.
22:38:27 T:636 NOTICE: Primary mode: [email protected] 60.00 - Full Screen
22:38:27 T:636 NOTICE: Additional mode: [email protected] 60.00 - Full Screen
22:38:27 T:636 NOTICE: Previous line repeats 2 times.
22:38:27 T:636 NOTICE: Checking resolution 16
22:38:27 T:636 NOTICE: No Joystick name specified, loading default map
22:38:27 T:636 NOTICE: Previous line repeats 35 times.
22:38:27 T:636 NOTICE: Running database version ViewModes6
22:38:27 T:636 NOTICE: Running database version Textures13
22:38:27 T:636 NOTICE: Running database version MyMusic46
22:38:27 T:636 NOTICE: Running database version MyVideos78
22:38:27 T:636 NOTICE: Running database version TV22
22:38:27 T:636 NOTICE: Running database version Epg7
22:38:28 T:636 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
22:38:28 T:636 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
22:38:28 T:1432 NOTICE: Thread LanguageInvoker start, auto delete: false
22:38:28 T:636 NOTICE: Previous line repeats 9 times.
22:38:28 T:636 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
22:38:28 T:3940 NOTICE: Thread VideoInfoScanner start, auto delete: false
22:38:28 T:4320 NOTICE: Thread LanguageInvoker start, auto delete: false
22:38:28 T:636 NOTICE: initialize done
22:38:28 T:3500 NOTICE: Thread LanguageInvoker start, auto delete: false
22:38:28 T:636 NOTICE: Previous line repeats 1 times.
22:38:28 T:636 NOTICE: Running the application...
22:38:28 T:636 NOTICE: Webserver: Starting...
22:38:28 T:4212 NOTICE: Thread AlarmClock start, auto delete: false
22:38:28 T:636 NOTICE: WebServer: Started the webserver
22:38:28 T:636 NOTICE: ES: Starting event server
22:38:28 T:3940 NOTICE: VideoInfoScanner: Starting scan ..
22:38:28 T:1076 NOTICE: Thread TCPServer start, auto delete: false
22:38:28 T:4292 NOTICE: Thread EventServer start, auto delete: false
22:38:28 T:4292 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
22:38:28 T:4292 NOTICE: UDP: Listening on port 9777
22:38:28 T:1432 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:3940 WARNING: VIDEO::CVideoInfoScanner::Process directory 'C:\Users\Destiny\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.genesis\TVShows\' does not exist - skipping scan.
22:38:28 T:3940 WARNING: VIDEO::CVideoInfoScanner::Process directory 'C:\Users\Destiny\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.genesis\TVShows\New Girl\' does not exist - skipping scan.
22:38:28 T:3940 WARNING: VIDEO::CVideoInfoScanner::Process directory 'dfsdffsfdfsdfdsfsd/' does not exist - skipping scan.
22:38:28 T:3940 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
22:38:28 T:3520 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:1912 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:4216 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:4748 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:4744 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:1136 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:3500 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:3640 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:5096 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:4892 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:4320 NOTICE: Previous line repeats 1 times.
22:38:28 T:4636 NOTICE: Previous line repeats 1 times.
22:38:28 T:4636 NOTICE: -->Python Interpreter Initialized<--
22:38:28 T:4908 NOTICE: Thread LanguageInvoker start, auto delete: false
22:38:28 T:5096 NOTICE: RCB Service: Start
22:38:28 T:5096 NOTICE: RCB Service: launch RCB on startup = false
22:38:28 T:5096 NOTICE: RCB Service: scrape games on startup = false
22:38:28 T:5096 NOTICE: RCB Service: Done
22:38:29 T:4164 NOTICE: Thread JobWorker start, auto delete: true
22:38:29 T:3456 NOTICE: Previous line repeats 2 times.
22:38:29 T:3456 NOTICE: Thread LanguageInvoker start, auto delete: false
22:38:29 T:3080 NOTICE: Thread JobWorker start, auto delete: true
22:38:29 T:4636 NOTICE: StorageServer Module loaded RUN
22:38:29 T:4636 NOTICE: StorageClient-2.5.4 Starting server
22:38:29 T:636 NOTICE: No Joystick name specified, loading default map
22:38:29 T:3640 NOTICE: Previous line repeats 35 times.
22:38:29 T:3640 NOTICE: script.grab.fanart: Grab Fanart Service Started
22:38:30 T:4908 NOTICE: -->Python Interpreter Initialized<--
22:38:30 T:3456 NOTICE: -->Python Interpreter Initialized<--
22:38:30 T:4748 NOTICE: script.lazytv : 0.002000 :: 0.002000 ::: - Running: Gotham
22:38:30 T:4748 NOTICE: script.lazytv : 0.002000 :: 0.000000 ::: - (0, 9, 93) started
22:38:30 T:4748 NOTICE: script.lazytv : 0.003000 :: 0.001000 ::: - randos = []
22:38:30 T:4748 NOTICE: script.lazytv : 0.003000 :: 0.000000 ::: - settings grabbed
22:38:30 T:4748 NOTICE: script.lazytv : 0.003000 :: 0.000000 ::: - monitor instantiated
22:38:30 T:4748 NOTICE: script.lazytv : 0.003000 :: 0.003000 ::: - variable_init_started
22:38:30 T:4748 NOTICE: script.lazytv : 0.004000 :: 0.001000 ::: - retrieve_all_shows_started
22:38:30 T:4748 NOTICE: script.lazytv : 0.026000 :: 0.022000 ::: - retrieve_all_shows_End
22:38:31 T:4908 NOTICE: CommonFunctions-2.5.1
22:38:31 T:4748 NOTICE: script.lazytv : 1.026000 :: 1.000000 ::: - get_eps_started
22:38:31 T:4748 NOTICE: script.lazytv : 0.297000 :: 0.297000 ::: - get_eps_Ended
22:38:31 T:4748 NOTICE: script.lazytv : 0.297000 :: 0.000000 ::: - variable_init_End
22:38:31 T:4748 NOTICE: script.lazytv : 0.297000 :: 0.000000 ::: - daemon started
22:38:31 T:3644 ERROR: XFILE::CFile::Delete - Error deleting file C:\Program Files (x86)\XBMC\portable_data\cache\weather\27.png
22:38:31 T:3644 ERROR: XFILE::CFile::Delete - Error deleting file special://temp/weather/27.png
22:39:01 T:636 NOTICE: CVideoDatabase::CleanDatabase: Starting videodatabase cleanup ..
22:39:01 T:4748 NOTICE: script.lazytv : 29.837000 :: 29.540000 ::: - notification!
22:39:01 T:636 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(plugin) in plugin://plugin.video.youtube/?path=/root/video&action=play_video&videoid=FgaYsGJGHP4
22:39:01 T:636 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(plugin) in plugin://plugin.video.genesis/?action=play&name=New+Girl+S01E03&title=Wedding&year=2011&imdb=1826940&tvdb=248682&season=1&episode=3&show=New+Girl&show_alt=New+Girl&date=2011-10-04&genre=Comedy&url=http%3A%2F%2Fwww.imdb.com%2Ftitle%2Ftt1826940%2F
22:39:01 T:636 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(plugin) in plugin://plugin.video.genesis/?action=play_moviehost&name=The+Nightmare+Before+Christmas+%281993%29&imdb=0107688&tvdb=0&url=http%3A%2F%2Fwww.iwatchonline.to%2Fplay%2F1883333&source=07+%7C+%5BB%5DIWATCHONLINE%5B%2FB%5D+%7C+STREAMIN+%7C+%5BI%5DMQ+%5B%2FI%5D&provider=Iwatchonline
22:39:10 T:636 NOTICE: CVideoDatabase::CleanDatabase: Cleaning videodatabase done. Operation took 00:08
22:39:10 T:4748 NOTICE: script.lazytv : 38.712000 :: 8.875000 ::: - notification!
22:39:16 T:4820 NOTICE: Thread BackgroundLoader start, auto delete: false
22:39:26 T:1864 NOTICE: Previous line repeats 2 times.
22:39:26 T:1864 NOTICE: Thread LanguageInvoker start, auto delete: false
22:39:26 T:1864 NOTICE: -->Python Interpreter Initialized<--
22:39:26 T:1864 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IOError'>
Error Contents: (13, 'Permission denied', 'C:\\Program Files (x86)\\XBMC\\portable_data\\userdata\\addon_data\\plugin.program.advanced.launcher\\launchers.xml')
File "C:\Program Files (x86)\XBMC\portable_data\addons\plugin.program.advanced.launcher-master\addon.py", line 20, in <module>
plugin.Main()
File "C:\Program Files (x86)\XBMC\portable_data\addons\plugin.program.advanced.launcher-master\resources\lib\launcher_plugin.py", line 100, in __init__
self._load_launchers(self.get_xml_source(BASE_CURRENT_SOURCE_PATH))
File "C:\Program Files (x86)\XBMC\portable_data\addons\plugin.program.advanced.launcher-master\resources\lib\launcher_plugin.py", line 1838, in get_xml_source
f = open(BASE_CURRENT_SOURCE_PATH, 'w')
IOError: (13, 'Permission denied', 'C:\\Program Files (x86)\\XBMC\\portable_data\\userdata\\addon_data\\plugin.program.advanced.launcher\\launchers.xml')
22:39:26 T:636 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.program.advanced.launcher/
22:39:26 T:636 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.program.advanced.launcher/) failed
22:39:26 T:4976 NOTICE: Thread BackgroundLoader start, auto delete: false
22:39:44 T:636 NOTICE: Previous line repeats 1 times.
22:39:44 T:636 NOTICE: Storing total System Uptime
22:39:44 T:636 NOTICE: Saving settings
22:39:44 T:636 NOTICE: stop all
22:39:44 T:636 NOTICE: stop player
22:39:44 T:636 NOTICE: ES: Stopping event server
22:39:44 T:636 NOTICE: Webserver: Stopping...
22:39:44 T:636 NOTICE: WebServer: Stopped the webserver
22:39:44 T:636 NOTICE: Webserver: Stopped...
22:39:44 T:4748 NOTICE: script.lazytv : 73.353000 :: 34.641000 ::: - notification!
22:39:45 T:4292 NOTICE: ES: UDP Event server stopped
22:39:45 T:636 NOTICE: stop sap announcement listener
22:39:45 T:636 NOTICE: clean cached files!
22:39:45 T:636 NOTICE: unload skin
22:39:47 T:1432 WARNING: CPythonInvoker(0, C:\Program Files (x86)\XBMC\portable_data\addons\script.cu.lrclyrics\default.py): the python script "C:\Program Files (x86)\XBMC\portable_data\addons\script.cu.lrclyrics\default.py" has left several classes in memory that we couldn't clean up. The classes include: class PythonBindings::XBMCAddon_xbmc_Monitor_Director,class PythonBindings::XBMCAddon_xbmc_Player_Director
22:39:47 T:3520 WARNING: CPythonInvoker(2, C:\Program Files (x86)\XBMC\portable_data\addons\service.skin.widgets\default.py): the python script "C:\Program Files (x86)\XBMC\portable_data\addons\service.skin.widgets\default.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Player_Director,class PythonBindings::XBMCAddon_xbmc_Monitor_Director
22:39:48 T:4636 NOTICE: StorageServer-2.5.4 Closed down
22:39:48 T:4748 NOTICE: script.lazytv : 77.158000 :: 3.805000 ::: - (0, 9, 93) stopped
22:39:49 T:1136 WARNING: CPythonInvoker(7, C:\Program Files (x86)\XBMC\portable_data\addons\service.library.data.provider\service.py): the python script "C:\Program Files (x86)\XBMC\portable_data\addons\service.library.data.provider\service.py" has left several classes in memory that we couldn't clean up. The classes include: class PythonBindings::XBMCAddon_xbmc_Monitor_Director,class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Player_Director
22:39:51 T:636 NOTICE: stopped
22:39:51 T:636 NOTICE: destroy
22:39:51 T:636 NOTICE: closing down remote control service
22:39:51 T:636 NOTICE: unload sections
22:39:51 T:636 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:39:51 T:636 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
22:39:51 T:636 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
22:39:51 T:636 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
22:39:51 T:636 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
22:39:51 T:636 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
22:39:51 T:636 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
22:39:51 T:636 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
22:39:51 T:636 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
22:39:51 T:636 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
22:39:51 T:636 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
22:39:51 T:636 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
22:39:51 T:636 NOTICE: application stopped...
