2015-03-13, 13:29
Hello friends,
Just a quickie. I'm wanting to restore a 38mb phpmyadmin database however when I try I'm told the max limit is 32mb.
I then get taken to a help file that says:
The first things to check (or ask your host provider to check) are the values of upload_max_filesize, memory_limit and post_max_size in the php.ini configuration file. All of these three settings limit the maximum size of data that can be submitted and handled by PHP. One user also said that post_max_size and memory_limit need to be larger than upload_max_filesize. There exist several workarounds if your upload is too big or your hosting provider is unwilling to change the settings:
I can't find the php.ini file in my \\192.168.x.x\web\phpMyAdmin folder.
Any ideas where this beast is kept? Or how else to get around this problem?
I'm running Kodi 13.2, Phpmyadmin is 4.3.0 on DSM 5.0
Thanks in anticipation
