2015-03-15, 12:04
first at all sorry for bad engilsh ! Hope you understand me...
I´m running Openelec 5.0.5 on a Rasperry Pi 2 as Frontend in my sleeping room. Backend is a VI+Duo2.
I´m very happy with this constellation ite works really great.
I have only one little problem.
On the Rasperry pi runs of course Aeon Nox. In life TV i can change the channels by pressing UP or DOWN an by pressing CHANNEL UP or CHANNEL DOWN.
What i wan´t is changing the channel not directly. I want to display the channel List (maybe with a little PiP) by pressing for example CHANNEL UP, then pressimg the same Key to go further up the List and switch to the selected channel by pressing ok.
If this ist not possible it would also be cool to press any key to go to the channel List and then select the channel by pressing ok.
Ist this possible to do withe aeon nox?
Best regards
Best regards
