Full Version: Aeon Nox Short Cut endless loop
Hi experts,
I am using openelec and win7 for kodi 14. In the standard skin I have no problem, but in the aeon nox skin the short cut add-on is going into an endless loop, so that I am not able to do anything, because the loop starts always in the main menu again, if I try to change to e.g. "films" or "music".
I am using mySQL database on a server which contains all of my media. Additionally I work with the PC Version of kodi to fill my mySQL database. Perhaps this is an interesting issue, because had the Feeling, that after using the win7 64Bit Kodi, and looking for new films in my database, the next start of openelec on another PC the Problem occured.
for Debugging my Problem...
I started debug mode in Skin "confluence" changed to "aeon nox". Then the behavior as described happened and I tried to come back to System settings and change the skin back to "confluence". The I stopped logging.
Here is my logfile.
http://xbmclogs.com/pelwyixzm
Hope someone can help.
Theo_tusch
Has nobody an idea?
1. There is no win 7 x64 version (has always been a windows x86 version)
2. Where did you source your KODI install file and addons from (They should always be from the official website: http://kodi.tv/download/ and official repo's)
3. The settings that work in the default confluence skin, do not necessarily reflect in the GUI of another skin and can cause issues.
Suggest you reset the confluence skin, then switch to Aeon Nox and add/configure the Aeon Nox skin via its own settings to add items to the main menu.
4. If you have sourced addon from non official repo, you could seek help from author of the addon if you do not get an answer here.
