2015-03-16, 03:15
At first I had XBMC on an old Acer Aspire Revo R3610. I had that up and running for several years, with varied amounts of success. I ran XBMCBuntu (is that what it was called) for a while, then moved over to OpenElec...both installed directly to the internal Hard Drive (not booting/running from the SD). More and more, though, I got frustrated with the frequency of buffering pauses and various unexplainable system freezes. I thought for a long time that the problem was with the way I was connected (Wi-Fi through a wireless access point to ethernet to the Revo), so I spent a ridiculous amount of effort finding a way to run a Gigabit RJ6 line to where the Revo was located. Long story short, no improvement.
About that time, the Raspberry Pi 2 was announced, and I figured that it would be an upgrade to the Revo, and a relatively inexpensive experiment. Again, long story short, no improvement. Some (most) videos stutter to buffer after playing less than 60 seconds. Some freeze at that point for a while then kick back to the file list / library. I tried all the advice I saw on a couple different "First things you need to do after installing XBMC on your Pi" blogs, including the Stuttering and Buffering advancedsettings.xml suggestions at http://www.htpcbeginner.com/raspberry-pi...ec-tweaks/ . If anything that seemed to make things worse.
I've got a Mac Mini PC in the office and a MacBook Pro that both have Kodi on them and neither of them has any issues with the videos that are choking the Pi2. So I'm not sure it's a matter of a problem with the video encodes (some downloads, but most are Handbrake mkv encodes from our personal DVD/Bluray collection).
But at this point, I'm at a loss. Part of me is compelled to look into building a more expensive / capably spec'd pc, like an Intel NUC, but the other part of me thinks this should work, based on others' apparent bliss running Kodi on a Pi, let alone a Pi2.
Is there a debug mode or something that would yield some log files that may report why it keeps choking? Please help me achieve the same success that others seem to be having with a Pi HTPC.
