Full Version: Chromebox and s3 resume
I have two problems after resuming from s3
My setup is
Asus chromebox with oe 5.0.6
Tv panasonic VT60
denon x2000
only one addon: Audio switcher to manual choose audio passthrough or not (already tried without it)
Sometimes after resume i couldn't get any audio or all files fails to start
For first problem i thinked about handshake problem but i tried also to disconnect/reconnect the hdmi cable without success
For the second problem like the first the only solution is to restart the chromebox
Anyone encountered same problem ?
Ps:which is the exact space color ? 16_235 or 0_255?
Thank you
If you read the Chromebox wiki the method to fix the audio problem is there. I has the same problem with the same av reciver. Basically you need to run a script to restart the audio and video after a resume. It's all documented.
Also I have a Panasonic g20 I use colour space 16 -235 (limited) the method to do this is also in the Wiki.
Link to wiki http://kodi.wiki/view/Chromebox
Ok i used putty to download the script
I don't understand if it installed correctly ...how can i check ? Big Grin
launched putty,login via ssh with root>openelec>pasted the script in the shell and i only see this message:
OpenELEC (official) Version: 5.0.6
OpenELEC:~ # mkdir -p /storage/.config/sleep.d
OpenELEC:~ # cd /storage/.config/sleep.d
OpenELEC:~/.config/sleep.d # curl -L -O https://dl.dropboxusercontent.com/u/9830...sume.power
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 164 100 164 0 0 236 0 --:--:-- --:--:-- --:--:-- 236
OpenELEC:~/.config/sleep.d # chmod +x 01-cbox_resume.power
thank you
I installed it but never tested until now cause the day tomorrow i left house for holidays and i take chromebox with me
I used it connected directly to a tv and no problem resuming from standby.
Today i come back to home and i reconnected it to my panasonic vt 60 and denon x2000 and uncluck i'm experiencing problem with resume
IF denon is on no problem switchin back from resume
IF denon is in standby with passthrough enabled i get blank screen from resume
If i connect directly to tv no problem
I also tried to restart the processor of denon but no luck
Do you know how to solve this problem and how can i uninstall the patch ?
