2015-03-17, 14:59
good day,
I use now some while Aeon Nox and it works fine until now, but at least for my device I have a small issue I like to address. With newer Versions of Kodi it seems on my device for example the shutdown/reboot does not work properly any more. I did take a look whats the difference between Aeon Nox and Confluence and I have seen that in the DialogButtonMenu.xml of AEON Nox (Version 5.6.0) it looks like :
<onclick>xbmc.Powerdown()</onclick>
and on Confluence (Version 2.7.0)
<onclick>Powerdown()</onclick>
therefore I removed from the Aeon Nox - DialogButtonMenu.xml the "xbmc." and voila - my device shutdown/restart again as it should.
Kind regards
Brujo
Kind regards
Brujo
