2015-03-17, 16:18
Kodi 14.2 and even experienced with earlier versions atv2 and now openelec on chromebox.
Add upnp source, browse to source, files and it loads with a waiting in the bottom right corner, files appear.
A new file is added to the server (UMS 5.0 configured to monitor this folder, also had with minidlna same behavior) and it doesn't appear in file list.
Update/refresh/watchdog does nothing.
Reboot machine will show new files after the waiting occurs.
I've scanned the entire filesystem to check for file size growth and it appears the upnp file list is being stored in RAM?
Is there any way to clear this ram and force it to reload with options or xml files or even python script using xbmc libraries?
