I have it working just fine in other edit controls but for some reason it doesn't want to work in the keyboard dialog.
This is a tricky one (i think) since the keyboard is not a real edit control.
No worries then, thought it was a simple bug.
Within the next few minutes there should be a win32 test build on the mirrors (with 'keyboard_hint' in the name). This is completely untested.. so don't blame me in case it's non-working
Oh cool, I thought this was a no-go.
I had to wait for some work stuff and took the opportunity to look at it. As said, i am not entirely sure if its working at all
Can test it later today (most likely) but thought i trigger a jenkins build while i am not around.
Uh, while having a second look i noticed that this won't work. You better use your time usefully
No need to test.
