Full Version: Slow refresh rate change with Baytrail
Issue: Slow refresh rate change. It takes some ~4 seconds. When clicking video, it starts playing audio, screen flickers.. freezes, changes rate, starts playing. This takes ~4 seconds.
However, this used to work almost instantaneously before.
I used to have Ubuntu 14.04 with Kodi added on top of it. After some upgrades this started happening.
Installed latest KodiBuntu - and same issue still there.
From logs this seems to be issue:
22:29:26 T:139759041115904  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
22:29:26 T:139759041115904  NOTICE: Creating video thread
22:29:26 T:139759041115904  NOTICE: Opening stream: 1 source: 256
22:29:26 T:139759007545088  NOTICE: Thread DVDPlayerVideo start, auto delete: false
22:29:26 T:139759007545088  NOTICE: running thread: video_thread
22:29:26 T:139759041115904  NOTICE: Finding audio codec for: 86019
22:29:26 T:139759041115904  NOTICE: Creating audio thread
22:29:26 T:139758999152384  NOTICE: Thread DVDPlayerAudio start, auto delete: false
22:29:26 T:139758999152384  NOTICE: running thread: CDVDPlayerAudio::Process()
22:29:26 T:139758999152384  NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, pass-through)
22:29:26 T:139758990759680  NOTICE: Thread Vaapi-Output start, auto delete: false
22:29:26 T:139758990759680  NOTICE: COutput::OnStartup: Output Thread created
22:29:26 T:139758898505472  NOTICE: Thread Vaapi-Output start, auto delete: false
22:29:26 T:139758898505472  NOTICE: COutput::OnStartup: Output Thread created
22:29:26 T:139759007545088  NOTICE: VAAPI::Close
22:29:26 T:139758990759680  NOTICE: COutput::OnExit: Output Thread terminated
22:29:26 T:139759007545088  NOTICE:  fps: 23.976024, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
22:29:26 T:139759007545088  NOTICE: Display resolution ADJUST : HDMI2: 1920x1080 @ 23.98Hz (21) (weight: 0.000)
22:29:26 T:139760531208128  NOTICE: CWinSystemX11::SetFullScreen - calling xrandr
22:29:32 T:139760531208128  NOTICE: Using GL_TEXTURE_2D
22:29:32 T:139760531208128  NOTICE: GL: Using VAAPI render method
22:29:32 T:139760531208128  NOTICE: GL: NPOT texture support detected
22:29:32 T:139760531208128  NOTICE: GL: Using GL_ARB_pixel_buffer_object
Actual 'issue' is after 'calling xrandr' - it takes 6 seconds for next part to happen.
Same when ending video:
22:32:02 T:139760531208128  NOTICE: DVDPlayer: finished waiting
22:32:02 T:139760531208128  NOTICE: VAAPI::Close
22:32:02 T:139758898505472  NOTICE: COutput::OnExit: Output Thread terminated
22:32:02 T:139760531208128  NOTICE: VAAPI::Close - closing decoder context
22:32:02 T:139760531208128  NOTICE: CWinSystemX11::SetFullScreen - calling xrandr
22:32:05 T:139758898505472  NOTICE: Thread BackgroundLoader start, auto delete: false
22:32:06 T:139760531208128   ERROR: CRenderManager::PrepareNextRender - asked to prepare with nothing available
22:32:06 T:139760531208128  NOTICE: CDVDPlayer::CloseFile()
22:32:06 T:139760531208128  NOTICE: DVDPlayer: waiting for threads to exit
Latest install is from: http://mirrors.xbmc.org/releases/kodibun..._amd64.iso
Info:
18:35:48 T:139760531208128  NOTICE: Starting Kodi (14.0 Git:ad747d9). Platform: Linux x86 64-bit
18:35:48 T:139760531208128  NOTICE: Using Release Kodi x64 build
18:35:48 T:139760531208128  NOTICE: Kodi compiled Dec 23 2014 by GCC 4.8.2 for Linux x86 64-bit version 3.13.11 (199947)
18:35:48 T:139760531208128  NOTICE: Running on Ubuntu 14.04.1 LTS, kernel: Linux x86 64-bit version 3.13.0-46-generic
18:35:48 T:139760531208128  NOTICE: FFmpeg statically linked, version: 2.4.4-xbmc-2.4.4-Helix
18:35:48 T:139760531208128  NOTICE: Host CPU: Intel(R) Celeron(R) CPU J1900 @ 1.99GHz, 4 cores available
Updating to latest updates (as of today) yields same issue.
Another interesting issue is when I open 'System menu', and hover mouse to 'Video output' - when it reaches it, it freezes for a few seconds too, before opening that panel.
Connected to TV via DVI 2 HDMI cable.
Again, this used to work perfectly fine, but at some point it got broken.
I've tried disabling other unused ports via xorg.conf:
Section "Monitor"
        Identifier "HDMI1"
        Option "Ignore" "True"
EndSection
Section "Monitor"
        Identifier "VGA1"
EndSection
Section "Monitor"
        Identifier "DP1"
EndSection
Section "Monitor"
        Identifier "DP2"
EndSection
This improved speed of 'xrandr -q' from about 1.2sec to 0.5sec.
However, what is interesting - if I log remotely and do 'xrandr -q' depending if in console window or in X window, I get waaay different results in speed:
In console window (CTRL+ALT+F1):
nfrances@xbmc:~$ time xrandr -q
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 32767 x 32767
HDMI2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 698mm x 392mm
   1920x1080      50.0*+   60.0     59.9     24.0     24.0
   1920x1080i     60.1     50.0     60.0
   1280x720       60.0     50.0     59.9
   1440x576i      50.1
   1440x480i      60.1     60.1
   720x576        50.0
   720x480        60.0     59.9
   640x480        60.0     59.9
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
real    0m0.008s
user    0m0.000s
sys     0m0.006s
nfrances@xbmc:~$
In X window (doesn't matter if KODI running, or X window session from KodiBuntu):
   1440x576i      50.1
   1440x480i      60.1     60.1
   720x576        50.0
   720x480        60.0     59.9
   640x480        60.0     59.9
real    0m0.438s
user    0m0.003s
sys     0m0.003s
nfrances@xbmc:~$
Any ideas?
Slow resolution change is really annoying Sad
And what do you have set in kodi settings?
like for e.g http://kodi.wiki/view/Settings/Videos#Playback and more specifically under
Pause during refresh rate change
Inserts a pause for the computer to adjust refresh rate. Sometimes needed to prevent things like slight stuttering when a video starts. Range 0.1 milliseconds to 20 seconds. (default off)
and please pastebin a full and complete debug log of you just doing this. So enable debug, restart kodi and immediatly playback a file that triggers refresh rate chnage and after its done its business grab log and pastebinit.
Spent few hours, and found the root cause.
It's video driver - i915_bdw
LiveCD KodiBuntu worked fine.
When i installed it to HDD, I noticed issues.
Checking for differences - noticed that LiveCD used i915 driver for video, while after installing it to disk it used i915_bdw driver.
I did upgrade to 3.13.0-48 kernel, and after blacklisting i915_bdw driver it used i915, however KODI was unusably slow and choppy, with few graphic artifacts.
I downgraded back to 3.13.0-43 kernel, also blacklisting i915_bdw driver, thus using i915 driver - and now it all worked fine!
Resolution change is instant.
So, issue is in i915_bdw driver.
Also, newer versions os i915 driver do not work good with J1900's graphic card.
Tried it.
It loads i915 driver, even though I removed i915_bdw from blacklist.
So far it seems to work fine!
All running smooth!
nfrances@xbmc:~$ uname -a
Linux xbmc 3.19.1-legacy-turbo+ #1 SMP Tue Mar 10 07:53:10 CET 2015 x86_64 x86_64 x86_64 GNU/Linux
nfrances@xbmc:~$ lsmod|grep ^video
video                  20271  1 i915
nfrances@xbmc:~$
