(2015-05-27, 05:42)phil65 Wrote: [ -> ]Would stuff like this be useful?
+1
You can start from negative number ?
Like for coverflow (from -7 to 7)
In case you get some error dialogs after latest GIT updates, just ignore them:
That´s because I switched from ".tmlanguage" files to the new syntax highlighting format ".sublime-syntax". Since ST first tries to open the old one which does not exist anymore, it throws an error dialog once. Everything should still work fine though.
(2015-05-27, 08:51)phil65 Wrote: [ -> ]ctrl+shift+r
Hi Phil.
Get latest GITHUB ZIP, replace lxml and PIL from arch branch to get 32 bits python includes.
But when I press ctrl+shift+r, I don't have the box to enter number of repeat.
When I look into default key-map, ctrl+shift+r is bind to :
{ "keys": ["ctrl+shift+r"], "command": "goto_symbol_in_project" },
Do we have to user key binding ?
no, should work out of the box.
add-on keymaps should have priority as far as i know. works here on 2 different machines.
Will make some tests on my 64 bits laptop this evening.
Also always Check console Output. Or try changing the Key combination in my plugin Keymap
(2015-05-27, 18:54)phil65 Wrote: [ -> ]In case you get some error dialogs after latest GIT updates, just ignore them:
Are you talking about this error dialog ?
Because after this error, I lost color coding :
Latest from GITHUB but I have to use lxml_32 and PIL_32 from arch branch because I'm running Windows 7 32 bits
Again : which sublimetext build? ;-)
Ok, thats too old for latest versions. You need at least 3084
But dev builds are availables only for register developpers :
http://www.sublimetext.com/3dev
When I run 3088, I must enter my licence key, which I don't have and I don't want to pay 70€ for it
70 Dollars, not Euros ;-) and license is usable for all your machines. If buying is not an option, then you have to wait
