2016-05-05, 17:53
2016-05-05, 18:19
Updated to 2.0.6 through Package Manager (so the upgrade function works well!), but still getting a 'NoneType' object has no attribute 'find' error
2016-05-05, 18:33
(2016-05-05, 18:19)BobCratchett Wrote: [ -> ]Updated to 2.0.6 through Package Manager (so the upgrade function works well!), but still getting a 'NoneType' object has no attribute 'find' error
Ok, will take a deeper look. Bit ugly to debug that stuff since I do not do the packaging locally.
2016-05-05, 18:39
Much appreciated, Phil. Let me know if there's anything I can do to help debug it.
2016-05-05, 18:49
2.0.7 is on its way, let me know if that fixes it.
2016-05-05, 20:12
No joy, but I added in some extra logging myself and believe I've tracked the problem - the ET.fromstring's are throwing the error:-
Removing the .getroot() seems to be working fine (another logging line shows that self.builtins and self.conditions are populating...)
AttributeError: 'lxml.etree._Element' object has no attribute 'getroot'
2016-05-05, 21:51
ok, thx. Next hotfix is on its way.
2016-05-05, 22:31
Working great. Thanks!
2016-05-05, 22:41
Thanks for the update
2016-05-12, 20:37
Next bigger update is out, 2.2.0:
- new context menu command: open skin image
- add syntax highlighting for several tooltips
- extended metadata info for image tooltips, and cache that info
- several bugfixes
- improved autocompletion
- polib upstream fixes
- fix running tool from command line
- reworked lot of code
Since a lot of refactoring was done I expect this version to have some regressions. Please post them here if you find some.
- several bugfixes
2016-05-13, 01:46
Hey phil,
I am having some difficulties and unsure what I may be doing wrong. I cannot seem to get any KodiDevKit options to appear (CNTRL + SHIFT + O) other than the ones that are visible before setting up the settings ie Remote Actions, Set Kodi Folder, and a few JSON-RPC choices. I also do not have any tooltip popups or jump to shortcut features working.
I see this in the Sublime Text log:
I have been setting up my settings by going to Preferences > Package settings > KodiDevKit but recently I had to add the folder "KodiDevKit" to my AppData\Roaming\Sublime Text 3\Packages\ directory to be able to save them (location did not exist). Since this last update I just cannot seem to get things working. I have tried reinstalling KodiDevKit using v2.2.0 also tried the repo version and have deleted all KodiDevKit.settings files I could find and lastly I tried saving a new project.
Usually after some trial and error things eventually start to work but I never knew why... If you need anymore info just let me know. Any help would be appreciated.
reloading plugin KodiDevKit.kodidevkit
File "C:\Program Files\Sublime Text 3\sublime_plugin.py", line 78, in reload_plugin
m = importlib.import_module(modulename)
File "./python3.3/importlib/__init__.py", line 90, in import_module
File "<frozen importlib._bootstrap>", line 1584, in _gcd_import
File "<frozen importlib._bootstrap>", line 1565, in _find_and_load
File "<frozen importlib._bootstrap>", line 1532, in _find_and_load_unlocked
File "C:\Program Files\Sublime Text 3\sublime_plugin.py", line 658, in load_module
exec(compile(source, source_path, 'exec'), mod.__dict__)
File "kodidevkit in C:\Users\SiLVO\AppData\Roaming\Sublime Text 3\Installed Packages\KodiDevKit.sublime-package", line 25, in <module>
ImportError: cannot import name infoprovider
2016-05-13, 02:00
Thx, I think i know the reason. Will get fixed.
2016-05-13, 02:08
2.2.1 is on its way.
On a sidenote, the git-tag based system from packagecontrol for managing updates is awesome. Doesnt take more than a minute to get an update out.
2016-05-13, 02:23
(2016-05-13, 02:08)phil65 Wrote: [ -> ]2.2.1 is on its way.Fixed, thank you! I didn't get the update through package control though... I stopped waiting, checking for updates, and just re-added the repo then reinstalled.
2016-05-19, 06:51
Hey phil,
Using the latest GitHub version and I see you have been updating some control stuff. I just noticed some things that seem incorrectly tagged as invalid Nodes / Attributes like the randomize tag for a fadelabel control added for Jarvis, <width> min & max, imagepath diffuse, and I think certain tweeners are missing. I also see onclicks showing as untranslated labels.
As always thank you for this plugin. It has helped me become a better skinner
