Full Version: KodiDevKit: SublimeText3 plugin to support kodi skinning / scripting
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Hmm.. 1x force close since yesterday after I copy/pasted a line.
hmm you could try to remove the "_async" from function name in line 25, no idea what else I could change.
My tip: Switch to linux, there it's rock solid, no crashes even though I have probably >10 plugins workin at the same time Wink
...or one more idea: change the 0 in line 27 to some higher value (it's the delay after which the tooltip appears, in milliseconds)
I'm not really sure if it was caused by the addon. It was working since hours.
I keep everything as it is for now, just to be sure.
Kodi core labels should also work now after having set up the path (can be done manually in settings file or by using the "Set Kodi Path" command)
Works great, Thanks!
But the plugin will also be triggered on end="100" (View: Icons) for example.
(2015-04-04, 18:54)sualfred Wrote: [ -> ]Works great, Thanks!
Well what do you expect when I call something "heavy WIP"?
Well, what do you expect from testers? Tongue
I will flood you with reports for every issue I'll find Smile
this plugin now also ships with custom kodi.log syntax highlighting^^
..forgot to mention, it needs very latest build from today (build 3084)
another small new feature: pressing shift + enter when focus is on a line in debug with an exception then it will jump to that file instantly. (thx to jindaxia)
Holy f*ckn sh*t did this thing just get even more awesome!
It cant do 'tail' can it?
at least not yet. It seems someone already gave it a shot, but I didnt look into it yet.
https://github.com/vifo/SublimeTail
Next feature:
pressing shift+enter while selection is on an image path in skin xmls will open an image preview.
https://github.com/phil65/SublimeKodi/co...c7a48a10e0
Also for info:
most features will require that you manage your skin / script folder as a project.
...also works for multiimage paths now Smile
