Full Version: KodiDevKit: SublimeText3 plugin to support kodi skinning / scripting
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
KodiDevKit
SublimeText plugin to help with Kodi Skinning and scripting
SublimeText 3 is available via PackageControl: https://packagecontrol.io/packages/KodiDevKit
Source:
https://github.com/phil65/kodidevkit
most up-to-date ReadMe + FeatureList:
https://github.com/phil65/kodidevkit/blo.../README.md
Needs build 3092+ to work properly!
some JSON functions need newest script.toolbox installed.
Everone is trying to move me from notepad++ to sublime.... but I'll resist Tongue
Thanks for sharing phil!
Very cool Phil. Definitely going to try this out.
@Sualfred: I was in the same boat but after trying it out I instantly switched to Sublime Text.
Is there a must have which I'm missing at np++? Tongue
Explorer plugin, intend and syntax tools, git integration, powerful search/replace tool, style configuration, customizable context menu. I mean.. I have everything and simply do not find a reason. Ok, this localize value plugin is a nice to have, but not really necessary for me.
Snippets, Multi-cursor, fuzzy search for fast project and file switching, much faster for searching large projects, to name a few. Also completely customizable in every aspect.
Also Check out this tutorial to get started :
http://code.tutsplus.com/articles/perfec...-net-27293
+1 for the multi cursor feature. This is awesome.
Thx for the link, I will take a deeper look into it tomorrow when I'm in the office.
This is brilliant! Thank you!
And well done!
@Phil Care to share the plugins you use?
(2015-03-19, 01:34)Hitcher Wrote: [ -> ]@Phil Care to share the plugins you use?
My ST installation here is mainly focused on Python development so probably not that helpful for you.
Apart from some obvious ones (Sidebar enhancements for example) I remember xmllint stuff being pretty important for skinning. BigNoid set up ST3 for skinning not too long ago so perhaps he can be more helpful in this aspect.
You can also browse a bit at https://packagecontrol.io/ to find stuff that suits your needs.
I have the following packages installed:
PHP Code:
    "installed_packages":
"GitGutter",
"Hooks",
"Indent XML",
"Package Control"
In combination with this keymap:
PHP Code:
// Move cursor to end of tag with Enter (xml only)
"keys": ["enter"], "command""move""args": {"by""characters""forward"true}, "context":
"key""following_text""operator""regex_contains""operand""^[>)'\"\\]]""match_all"true },
"key""auto_complete_visible""operator""equal""operand"false },
"key""selector""operator""equal""operand""text.xml" }
// Replace = with ="" and move cursor (xml only)
"keys": ["="], "command""insert_snippet""args": {"contents""=\"$0\""}, "context":
// Create tag when < is typed (xml only)
"keys": ["<"], "command""insert_snippet""args": { "name""Packages/XML/long-tag.sublime-snippet" }, "context":
// Reindent
"keys": ["ctrl+alt+r"], "command""reindent" },
Thanks guys, I'm almost converted but how do I use your keymap exactly?
Preferences-->Key Bindings - User
Paste the code in that screen.
Re-indent is used in combination with the Indent XML package, select text and press ctlr+alt+r to indent.
Soo.... played a while with Sublime. Realy powerful but I guess I'll stick at np++ for now. Simpy too used to it Tongue
I'm converted with the auto-complete and multi-cursor functions. Just couldn't use v3 though as the packet manager had all sorts of problem.
(2015-03-20, 01:30)Hitcher Wrote: [ -> ]I'm converted with the auto-complete and multi-cursor functions. Just couldn't use v3 though as the packet manager had all sorts of problem.
install this way:
https://packagecontrol.io/installation
and make sure it is not listed under Preferences --> Settings - User --> ignored packages.
newest version here: http://www.sublimetext.com/3dev
