Hi, I can't get to work with Wd Mybook studio hd 4tb ntfs usb 3
Here is my log
OpenELEC (official) Version: 5.06
http://sprunge.us/CXXb
With a wd passport 500gb usb 3 perfectly works
I don't see any error only a mark about large hard disk
Is it an option for you to repartition it as suggested in the openelec thread?
or at the very least, update the thread with the requested info so you can help the devs troubleshoot the issue
(2015-03-19, 05:24)nickr Wrote: [ -> ]Is it an option for you to repartition it as suggested in the openelec thread?
i suppose that i can't repartion without losing data ?
(2015-03-19, 05:56)Matt Devo Wrote: [ -> ]or at the very least, update the thread with the requested info so you can help the devs troubleshoot the issue
Yes, already done
Maybe if exist can work with a usb to rj45 adapter ?
What about if i format it in ext4 ?
Solved, was only a problem of ejecting correcly the disk in windows
so you're saying OE wouldn't mount the partition since it was marked as dirty? that should have been easy to diagnose from either the log or via an attempted manual mounting
