2015-09-06, 21:12
Sorry if I missed the answer... is there a Synology package created for this branch? All I can find it is OLD one on SynoCommunity - it does not allow use to choose a branch
thx
thx
(2015-09-06, 21:12)Livin Wrote: [ -> ]Sorry if I missed the answer... is there a Synology package created for this branch? All I can find it is OLD one on SynoCommunity - it does not allow use to choose a branch
thx
(2015-09-06, 21:14)hellow Wrote: [ -> ](2015-09-06, 21:12)Livin Wrote: [ -> ]Sorry if I missed the answer... is there a Synology package created for this branch? All I can find it is OLD one on SynoCommunity - it does not allow use to choose a branch
thx
Not atm, there is a pr waiting review.
(2015-09-06, 21:16)Livin Wrote: [ -> ](2015-09-06, 21:14)hellow Wrote: [ -> ](2015-09-06, 21:12)Livin Wrote: [ -> ]Sorry if I missed the answer... is there a Synology package created for this branch? All I can find it is OLD one on SynoCommunity - it does not allow use to choose a branch
thx
REALLY looking forward to this!
(2015-09-06, 22:39)Livin Wrote: [ -> ]I installed the SynoCommunity version... then SCP'd into the NAS and deleted all the files, copied over the files from your repo. Seems to be working. I even ran an update.
happy camper!
(2015-09-22, 09:53)babaloui Wrote: [ -> ]Thanks for this great software.
Would it be possbile to have an option to show a list instead of the slidshow for "Latest Episodes" and "Latest Movies"?
Similare to "Next Aired" and "Wanted Movies".
Thanks,
Robert
(2015-09-22, 12:45)hellow Wrote: [ -> ](2015-09-22, 09:53)babaloui Wrote: [ -> ]Thanks for this great software.
Thanks,
Robert
Thanks for the kind words.
Latest episodes and latest moves of what? plex or kodi? or both?
I can do that, but im a little busy atm so i have no eta.
(2015-09-22, 13:32)babaloui Wrote: [ -> ]Why don't you access it directly or via a reverse proxy?(2015-09-22, 12:45)hellow Wrote: [ -> ](2015-09-22, 09:53)babaloui Wrote: [ -> ]Thanks for this great software.
Thanks,
Robert
I was thinking for Kodi , but that's just my case. I use it as a status page when remoting into my server via TeamViewer and the slidshowing pictures makes the page a little laggy in my case, I also think a list gives an easier and quicker overview.
Also (let me know if this is the wrong thread for it), where do you configure what is shown on a per disk basis for S.M.A.R.T? Mine now shows sdc, sdd, sde, sdf etc, this makes no sense to me in a windows system and also the disk are raided, would it be possible to show the serial number of the disk instead?
Thanks,
Robert
EDIT
(2015-09-22, 14:34)hellow Wrote: [ -> ](2015-09-22, 13:32)babaloui Wrote: [ -> ]Why don't you access it directly or via a reverse proxy?(2015-09-22, 12:45)hellow Wrote: [ -> ]Thanks for the kind words.
Thanks,
Robert
EDIT
Im not sure i understand what your asking here. Can you post a screenshot?
(2015-09-22, 22:17)Jdiesel Wrote: [ -> ]Thank you for your work on this software.
I have a couple of questions/requests:
1. The settings for Mylar have no option for login credentials, can this be added?
2. Is there a way to get S.M.A.R.T. data when running HTPC-Manager as a service with NSSM?
3. Finally, I seem to be getting the following error when connecting to Deluge:
Failed to fetch method web.connected arguments [] ('Connection aborted.', BadStatusLine("''",))
(2015-09-22, 22:28)hellow Wrote: [ -> ](2015-09-22, 22:17)Jdiesel Wrote: [ -> ]Thank you for your work on this software.
Im glad you find it usefull.
1. Why do you need it? The module uses the apikey to authenticate.
2. No that i know off, I dont use NSSM. If you can find a way to start it with elevated shell it should work.
3. Dunno, can you read https://github.com/Hellowlol/HTPC-Manage...-bug-great then open a issue on github?
