Full Version: Hellowlol HTPC-Manager fork support thread
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
Since there are been posted some issues regarding my fork in http://forum.kodi.tv/showthread.php?tid=126297 i thought it was best to open a new thread.
If you havnt found any new updates after Mar 1, 2015 you need to use the force update from the settings page or update manually.
My fork includes everything styxit and some improvements
New modules:
- sonarr
- torrentsearch (btn, ptp, norbits, kat, and YTS)
- Sickrage
- headphones
- Samsung tvremote
- vnStat
- mylar
There are various improvements in the existing modules
- CP: Basic controls like restart, postprocess, set label and category while adding a movie, suggestion and charts tabs.
- SAB: reorder download que with drag and drop
- Stats: Is sortable and you can see hardware info and smart rapport.
- Transmission: add url, upload local torrent
- Kodi added a addons tab where you can search, enable/disable addons
- Newznab: Send nzbs directly to sab, nzbget or download them to your browser.
- Dashboard supports drag and drop, top link and other links can be moved around to the wanted position.
- nzbget rewritten, now supports changing category, upload nzb and nzb url
Misc
- Htpc-Manager uses the entire screen
- The brave and bold can choose what branch to use.
- Added argsparse to support python 2.6
- Delete cache button
- Force update button
- Added a option to keep crawlers from your site
- .cert and key is made your you automatically unless your provide a path for it.
- Apikey's, passwords etc are masked in the log
- And probably a lot more i don't remember
Report issues/feature requests on github, please read the issue guidelines before doing so.
You can find the fork here
Anything else goes here Smile
Screenshot of some of the features
Edit dashboard
Stats Hardware info tab
Edit menu
SMART report
sonarr
vnStat
reserved_
A S.M.A.R.T tab was just added to the stats module. Thanks wmariz!
The dashboard now supports drag and drop, the order is saved to the db. No more empty space. Thanks wmariz
The links other can be moved and saved to db.
Added support for mylar
stixit should turn this project over to you. It's passed several times and now you are the only one that cares.
(2015-05-14, 23:47)MadClicker Wrote: [ -> ]stixit should turn this project over to you. It's passed several times and now you are the only one that cares.
Thanks for the vote of confidence! Having a really small userbase if comforting when you break stuff. (Like I did with the Mylar commit....)
I though it had one been passed over once?
Awesome work bro.
just wanted to say i recently switched to your fork, love the new features,
any chance of fixing this small mis-allignment issue?
Any custom links don't match the allignment of non custom links.
I just merged a pr that should fix that issue. The pr is untested but I have some spare time today so I'll fix it if it doesn't work.
Im glad you like it!
(2015-05-18, 17:08)fma965 Wrote: [ -> ]just wanted to say i recently switched to your fork, love the new features,
First, thank you for posting this, it's good to know I'm not the only one whose eye starts to twitch at little things like that.
Second, I found if you add a second link so it's a dropdown, the alignment is proper.
Stopped using this a while ago until I saw your fork, it is all working great.
Except connecting to qbittorrent. I can connect to local qbittorrent but not qbittorrent-nox on my server (just webui verstion as it's a headless server) for some reason.
(2015-05-20, 07:52)three80 Wrote: [ -> ]Stopped using this a while ago until I saw your fork, it is all working great.
Please make a proper issue on github and I'll try to fix it Smile
Absolutely what info do you want? where are the logs stored?
EDIT: Nvm found log.. proceeding to gather info and post to github.
