(2015-06-21, 17:14)braz Wrote: [ -> ]Thanks! You downloaded the latest from git and manually installed it in Helix? Upgrade to Isengard for best results with the new version.
The background file is default_bg.jpg in the skin's backgrounds folder. Just replace that file with your own. I tried adding a skin setting to allow users to pick their own background, but unfortunately it's not possible with the way backgrounds are currently coded (can't use a $VAR for the fallback).
I downloaded it a long time ago and haven't been using it but Helix must have kept it updated. I upgraded to Isengard a few days ago and didn't do anything with the skin. I was wondering if it was still running the Helix version. Is there even a difference?
Big difference between 1.x (helix) and 2.x (isengard). Not sure if it will auto update, assuming it does though. You should be on 2.1.1 if it updated from the repo.
How difficult to add an opacity selector for the fanart overlay?
(2015-06-22, 05:59)Dojoroda Wrote: [ -> ]How difficult to add an opacity selector for the fanart overlay?
No plans to add anything like that, you'll have to edit background.png.
Lazy TV context menu will only scroll up or down, and not around and round...fixable?
(2015-06-23, 21:18)Dojoroda Wrote: [ -> ]Lazy TV context menu will only scroll up or down, and not around and round...fixable?
Just checked the code, I see what is likely the issue. Will test tonight.
Update: Fix pushed to git, will be in the next version.
Minor issue. The skin is playing tv tunes even though I have it turned off. Is there a fix?
First of all: Love the Skin!
Quick Question: Is there a way to remove the Pause symbol in the middle of the screen?
I removed it once before in Mimic 1.x but now I can't seem to find the png or code in the xml to remove it.
Any help is appreciated.
(2015-06-26, 01:54)Kyselak Wrote: [ -> ]First of all: Love the Skin!
DialogSeekbar.xml, line 187. Or just delete media/osd/paused.png if you installed from github.
(2015-06-26, 03:06)braz Wrote: [ -> ] (2015-06-26, 01:54)Kyselak Wrote: [ -> ]First of all: Love the Skin!
Thanks so much. Works like a charm.
(2015-06-23, 21:25)braz Wrote: [ -> ] (2015-06-23, 21:18)Dojoroda Wrote: [ -> ]Lazy TV context menu will only scroll up or down, and not around and round...fixable?
THANKS, IMPRESSIVE WORK. YOU ARE A PRINCE!
Just pushed a big update to github. Redesigned all of the panel layouts with Phil65's design. You'll recognize it when you try it out. Still have a few things to iron out, but most of the work is done. Still need to do the Extended Info dialog panels.
braz,
poster view, white folder needs to move slightly to left. You can see the problem if you select the last movie of your collection, white folder to the right, than first movie to the right of the folder. hope it makes sense
braz,
I was watching a movie, paused and pulled info screen. It shows the name of the movie, and after the name chapter 2/15. Is there a way to turn this off? I went back to the first post and went over the images you posted and didn't see this
thanks
When in a TV Series show shouldnt it display only the (extra) fanart of this series?
Now when im GoT for example i see Sense8, Orange is the new black and other fanart.
Im running 2.20 from git.
