2015-04-14, 06:32
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
2015-04-14, 06:32
2015-04-15, 06:01
2015-04-18, 02:06
2015-04-19, 00:58
Like the Global search. Thx for the constant updates.
It's been a while since i modded skins. Would you be able to tell me which xml files I would need to mod to add an existing view to a generic video files view (specifically Low list)?
2015-04-20, 04:39
(2015-04-19, 00:58)handbone Wrote: [ -> ]Like the Global search. Thx for the constant updates.
You want to be able to use LowList view when browsing files? Look for the LowList item in custom_1118_ViewtypeMenu.xml and add "Container.Content(files)" to the visibility condition. I tested it out but couldn't come up with a good solution for what to do with the file icon.
FYI, I just added the LowList view for Addons and Programs.
2015-04-20, 21:02
(2015-04-20, 04:39)braz Wrote: [ -> ](2015-04-19, 00:58)handbone Wrote: [ -> ]Like the Global search. Thx for the constant updates.
Thats Alright. It mainly for My F1 files. I have the posters and fanart setup for it. I'm mainly going to use it for that. So I don't expect you to add it since its more of a personal fix and won't look god elsewhere. Thx.
* Worked perfecly for my F1 videos... As for the file Icon. I'm not sure if its possible/looks good, but maybe making a generic video poster? This is a very quick mockup, but something like this....
But not sure if something like that would mix in with your theme. But like I said. this was more for my own personal use for F1 as i am to lazy to make nfo's for them and add it to the TV section
2015-04-21, 07:32
Started playing around on an alternative Home screen, which can be selected in the skin settings (in git version). If you try it out, let me know what you think. Infolines, rss, and now playing are not displayed in this Home screen, will see if there is a place to put them. Now playing will likely make its way back...
watch gallery
2015-04-21, 08:02
(2015-04-20, 21:02)handbone Wrote: [ -> ]But not sure if something like that would mix in with your theme. But like I said. this was more for my own personal use for F1 as i am to lazy to make nfo's for them and add it to the TV sectionYeah, not sure it will fit in with the rest of the skin, thanks though!
2015-04-22, 07:24
2015-04-22, 12:14
Quick typo spot: shouldn't "recenty added" be "recently added"?
2015-04-22, 16:38
(2015-04-22, 12:14)Tiny Clanger Wrote: [ -> ]Quick typo spot: shouldn't "recenty added" be "recently added"?What language are you using? I can't find the typo in English or English (US).
2015-04-23, 10:27
(2015-04-22, 16:38)braz Wrote: [ -> ](2015-04-22, 12:14)Tiny Clanger Wrote: [ -> ]Quick typo spot: shouldn't "recenty added" be "recently added"?What language are you using? I can't find the typo in English or English (US).
Ah, that was in the submenu in that first screengrab up above - might already have been fixed in the repo
2015-04-23, 12:33
Can I just say that both the top-menu and left-vertical-menu options look great. This skin just gets better and better!
Thanks for your work on it!
~Jondar
~Jondar
2015-04-23, 15:36
(2015-04-23, 10:27)Tiny Clanger Wrote: [ -> ]Ah, got it. That's a typo in my submenu (doesn't affect others), will fix it. Thanks!(2015-04-22, 16:38)braz Wrote: [ -> ](2015-04-22, 12:14)Tiny Clanger Wrote: [ -> ]Quick typo spot: shouldn't "recenty added" be "recently added"?What language are you using? I can't find the typo in English or English (US).
2015-04-24, 07:17
