(2015-10-27, 01:33)braz Wrote: [ -> ] (2015-10-26, 11:06)meccs Wrote: [ -> ]Can you please tell me how I can change the time for the random background artwork? It changes too quick imo. Thanks and keep up the good work!
If I remember correctly, open up the Defaults.xml and change the timeperimage value for multiimage controls. For example, change the value from 7000 to 15000.
Just found out that it does only have an effect if I select the "multi image option" and select a folder but has no effect on the "random movie background" option.
If someone wants to do this:
The Fanart thing is set via the script.grab.fanart. Inside kodi/addons/script.grab.fanart/resources/ edit the "Settings.xml" file. There is a default="10" option which means 10 seconds. Change it to whatever you want.
meccs
Didn't know this, thanks for sharing.
Is there a way to hide some addons in my widgets, or to create a custom list of addons to use? I have about 20 video addons installed, but I would like it if I could only have about half of them show up in my widgets.
Edit - I do see there is a "custom widgets" option, but I can't figure out if it can do what I want.
Hello, [/php]I am getting ExtendedInfo Script Error when I open info dialog.
:139928667145984 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=y5Bus1IPuCc
10:12:30 T:139928667145984 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=-bA7tBoJBK0
10:12:30 T:139928667145984 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=Hto3Jbawc1g
10:12:30 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=rFDDOwP65rw
10:12:30 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=COeGZk_V9n8
10:12:32 T:139928541320960 NOTICE: Thread LanguageInvoker start, auto delete: false
10:12:32 T:139928541320960 NOTICE: Previous line repeats 2 times.
10:12:32 T:139928541320960 NOTICE: -->Python Interpreter Initialized<--
10:12:32 T:139928541320960 NOTICE: version 3.1.1 started
10:12:33 T:139928541320960 NOTICE: Previous line repeats 1 times.
10:12:33 T:139928541320960 NOTICE: finished
10:12:34 T:139927991142144 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: int() argument must be a string or a number, not 'NoneType'
File "/storage/.kodi/addons/script.extendedinfo/plugin.py", line 91, in <module>
Main()
File "/storage/.kodi/addons/script.extendedinfo/plugin.py", line 21, in __init__
start_info_actions(self.infos, self.params)
File "/storage/.kodi/addons/script.extendedinfo/resources/lib/process.py", line 249, in start_info_actions
orderby=params.get("orderby", "relevance"))
File "/storage/.kodi/addons/script.extendedinfo/resources/lib/YouTube.py", line 137, in search_youtube
videos = handle_youtube_videos(results["items"], extended=True)
File "/storage/.kodi/addons/script.extendedinfo/resources/lib/YouTube.py", line 52, in handle_youtube_videos
vote_count = float(int(ext_item['statistics'].get('likeCount')) + int(ext_item['statistics'].get('dislikeCount')))
TypeError: int() argument must be a string or a number, not 'NoneType'
10:12:34 T:139928667145984 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=youtubesearch&&id="22 Jump Street" TV show
10:12:38 T:139928373532416 NOTICE: Thread LanguageInvoker start, auto delete: false
10:12:38 T:139928373532416 NOTICE: Previous line repeats 2 times.
10:12:38 T:139928373532416 NOTICE: -->Python Interpreter Initialized<--
10:12:38 T:139928373532416 NOTICE: version 3.1.1 started
10:12:38 T:139928373532416 NOTICE: finished
10:12:38 T:139929413736192 NOTICE: version 3.1.1 started
10:12:38 T:139928398710528 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=NBIcbB4wXk4
10:12:38 T:139929413736192 NOTICE: finished
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=eveyV0_gdIY
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=Hy5ZudekRsM
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=gk0s9ZOv9po
10:12:38 T:139929061406464 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=slxvTJFvhj4
10:12:38 T:139929061406464 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=qBlN0aIiRE8
10:12:38 T:139928398710528 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=xKsz03imUwc
10:12:38 T:139928398710528 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=z5Q356C4Usg
10:12:38 T:139928398710528 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=YzeqmXdPYrM
10:12:38 T:139928398710528 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=Xyd0E66i9EQ
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=ABW0Pjz4upk
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=JgvsDZlm9ps
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=sXTK6BuqOig
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=E-HpwQPpPxI
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=yC1Speg66Vg
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=v7SBifJyeBk
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=PaUYYPf1P2E
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=U-ZB2YDxeGM
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=obxSoVl10N8
10:12:38 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=NZruzu5JOkQ
10:12:42 T:139929413736192 NOTICE: Thread LanguageInvoker start, auto delete: false
10:12:42 T:139929413736192 NOTICE: Previous line repeats 2 times.
10:12:42 T:139929413736192 NOTICE: -->Python Interpreter Initialized<--
10:12:42 T:139929413736192 NOTICE: version 3.1.1 started
10:12:42 T:139928191702784 NOTICE: Previous line repeats 1 times.
10:12:42 T:139928191702784 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Main()
10:12:42 T:139928398710528 ERROR: Previous line repeats 1 times.
10:12:42 T:139928398710528 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=youtubesearch&&id="21 Grams" TV show
10:12:42 T:139928809756416 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=youtubesearch&&id="21 Grams" Movie Trailer
10:12:50 T:139928373532416 NOTICE: Thread LanguageInvoker start, auto delete: false
10:12:50 T:139928373532416 NOTICE: -->Python Interpreter Initialized<--
10:12:50 T:139928373532416 NOTICE: version 3.1.1 started
10:12:57 T:139928373532416 NOTICE: finished
10:12:59 T:139928373532416 NOTICE: Thread LanguageInvoker start, auto delete: false
10:12:59 T:139929413736192 NOTICE: Previous line repeats 2 times.
10:12:59 T:139929413736192 NOTICE: -->Python Interpreter Initialized<--
10:12:59 T:139928373532416 NOTICE: Previous line repeats 2 times.
10:12:59 T:139928373532416 NOTICE: version 3.1.1 started
10:12:59 T:139928373532416 NOTICE: finished
10:12:59 T:139928191702784 NOTICE: version 3.1.1 started
10:12:59 T:139928191702784 NOTICE: finished
10:12:59 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=NBIcbB4wXk4
10:12:59 T:139929061406464 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=eveyV0_gdIY
10:12:59 T:139928667145984 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=Hy5ZudekRsM
10:12:59 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=gk0s9ZOv9po
10:12:59 T:139929061406464 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=slxvTJFvhj4
10:12:59 T:139928667145984 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=qBlN0aIiRE8
10:12:59 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=xKsz03imUwc
10:12:59 T:139929061406464 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=z5Q356C4Usg
10:12:59 T:139928667145984 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=YzeqmXdPYrM
10:12:59 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=Xyd0E66i9EQ
10:12:59 T:139929061406464 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=ABW0Pjz4upk
10:12:59 T:139928667145984 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=JgvsDZlm9ps
10:12:59 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=sXTK6BuqOig
10:12:59 T:139929061406464 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=E-HpwQPpPxI
10:12:59 T:139928667145984 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=yC1Speg66Vg
10:12:59 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=v7SBifJyeBk
10:12:59 T:139929061406464 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=PaUYYPf1P2E
10:12:59 T:139928667145984 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=U-ZB2YDxeGM
10:12:59 T:139928809756416 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=obxSoVl10N8
10:12:59 T:139929061406464 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=youtubevideo&&id=NZruzu5JOkQ
10:13:05 T:139928191702784 NOTICE: Thread LanguageInvoker start, auto delete: false
10:13:05 T:139928191702784 NOTICE: Previous line repeats 2 times.
10:13:05 T:139928191702784 NOTICE: -->Python Interpreter Initialized<--
10:13:05 T:139928191702784 NOTICE: Previous line repeats 1 times.
10:13:05 T:139928191702784 NOTICE: version 3.1.1 started
10:13:05 T:139929413736192 NOTICE: -->Python Interpreter Initialized<--
10:13:05 T:139929413736192 NOTICE: version 3.1.1 started
10:13:05 T:139928191702784 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Main()
10:13:05 T:139928667145984 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=youtubesearch&&id="21 Grams" Movie Trailer
10:13:05 T:139929413736192 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Main()
10:13:05 T:139929061406464 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=youtubesearch&&id="21 Grams" TV show
10:13:09 T:139928373532416 NOTICE: Thread LanguageInvoker start, auto delete: false
10:13:09 T:139928373532416 NOTICE: Previous line repeats 1 times.
10:13:09 T:139928373532416 NOTICE: -->Python Interpreter Initialized<--
10:16:50 T:139927949178624 NOTICE: Previous line repeats 1 times.
10:16:50 T:139927949178624 NOTICE: Thread LanguageInvoker start, auto delete: false
10:16:50 T:139927949178624 NOTICE: -->Python Interpreter Initialized<--
10:17:37 T:139928191702784 NOTICE: Thread LanguageInvoker start, auto delete: false
10:17:37 T:139928191702784 NOTICE: -->Python Interpreter Initialized<--
10:17:37 T:139928191702784 WARNING: CPythonInvoker
Tomislawww
Please post addon bug reports in the respective addon threads and use pastebin.com rather than posting the log directly on the forum.
(2015-11-02, 15:38)dkplayaclub Wrote: [ -> ]Is there a way to hide some addons in my widgets, or to create a custom list of addons to use? I have about 20 video addons installed, but I would like it if I could only have about half of them show up in my widgets.
bump
Can I just interpret the lack of response as a "no"?
First of all I am loving this amazing skin so thanks for youre great work here!!!!!
I am still a rookie and had yesterday an update to the final 15.2 (openelec/RP2) and I was looking for a new skin in the repo and I finaly found this nice skin and I wanted to use multiple backround Pictures for all my sections like Movies, Pictures ect. The problem is that when I try to use the option for more than only one backround I can´t see the backrounds in my folder to choose all the backrounds I want to have. If I use the option for only one backround I can see all of my pictures. Is there something I still have to download like another addon?
(2015-11-11, 11:47)ugotit Wrote: [ -> ]First of all I am loving this amazing skin so thanks for youre great work here!!!!!
With the multi image option you are picking a folder rather than an image so it's normal that you don't see the photos. Just browse to the folder of images you want to use and click OK.
(2015-10-27, 10:50)meccs Wrote: [ -> ] (2015-10-27, 01:33)braz Wrote: [ -> ] (2015-10-26, 11:06)meccs Wrote: [ -> ]Can you please tell me how I can change the time for the random background artwork? It changes too quick imo. Thanks and keep up the good work!
I feel the same thing that it changes to quick and I tried to follow this guide but I can´t see this default.xml ether the script.grab.fanart. Is this because you guys maybe talking about a PC Version or can you guys give me an advise for the openelec RPI 2 version?
EDIT: I still have to understand a little bit more the way all this things with addons und settings work but I found the script grab fanart and tried to set the time but the changes doesnt´t effect the time for backround Pictures folder for my catagories so I think this only works for the setup with fanart work. So I still need to find this Default.xml so I hope someone can tell me where to find it please?
EDIT for the last time: It was a hard birth but finaly didi it. My problem was that my Windows PC can´t handle linux partitions and on my sd card with openelec installed I only saw the typical folders withe userdata ect. and after I found an articel in the openelec forum with a similar problem I´ve downloaded a little tool "Paragon ExtFS for Windows" and after that it shows all the partitons. Finaly I saw the folder with the default.xml and changed the time from 7000 to 20000 and now it changes every 20 seconds.
Hi, thanks a lot for this nice and easy to use skin.
just a small question please, can you tell me how to set item background for "Favorites"? I see my backgrounds for "Movies, TV Shows, System, Weather .....etc". But for "Favorites" I only see it in the home view, but when I open it, it's still your black background. Thanks in advance.
I´d like to know the values for the catagory Movie - subemenu - ...in progress and how to change them. When I go to sleep I always put a movie on with a sleeptimer for 30-60 minutes and I tought I find the next night the movie from yesterday in the submenu under "in progress" so I don´t need to look for him again in my hole library but it isn´t so. So how can I change this things? Another question is I want to know if there is an option for the submenu to have a catagory for the last 10 watched movies too?
(2015-11-23, 15:59)ugotit Wrote: [ -> ]I´d like to know the values for the catagory Movie - subemenu - ...in progress and how to change them. When I go to sleep I always put a movie on with a sleeptimer for 30-60 minutes and I tought I find the next night the movie from yesterday in the submenu under "in progress" so I don´t need to look for him again in my hole library but it isn´t so. So how can I change this things? Another question is I want to know if there is an option for the submenu to have a catagory for the last 10 watched movies too?
The first issue isn't really a skin issue, the skin displays whatever the script provides. For the second question, can you create a playlist of recently watched movies and add it to your submenu?
