2015-03-19, 17:12
Win 7 32bit SP1
3gb RAM
Xeon 3210. Basically a C2Q Q6400
Geforce 210
All media files played locally. SD all the way up to 1080p have the same issue.
Every 10 minutes or so I notice the video will freeze for a second, then speed up to catch up with audio. This is especially noticeable on panning shots
This has been a problem for me since Kodi 14.0. I never had an issue with 13.2 and no hardware changed between the upgrade. I continued upgrading to 14.1 and currently 14.2 rc hoping it would be fixed but the issue is still there. I have also tried uninstalling and deleting the Kodi folder in my AppData to get a fully clean install but still have the issue.
Only addon I have is the keymap editor.
Tried sync playback to display or adjust display refresh rate to match video and still freezing. Also tried software decoding.
Below is what is in the log file when it happens. CDVDClock:iscontinuity is one of the times the video would freeze. I believe CDVDClock:iscontinuity appears each time I get the video freeze.
Full log file DXVA
Full log file Software
I found this bug report that may reference the same issue, but it is so old and was never resolved. http://trac.kodi.tv/ticket/9320
I have reinstalled 13.2 and it still plays fine so it is definitely something with 14+
3gb RAM
Geforce 210
20:27:25 T:4140 DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
20:27:44 T:3528 DEBUG: CDVDClock::Discontinuity - CDVDPlayerAudio::HandleSyncError2 - was:2028919324.829480, should be:2028909289.041514, error:-10035.787966
20:33:42 T:3528 DEBUG: CDVDClock::Discontinuity - CDVDPlayerAudio::HandleSyncError2 - was:2386642476.007245, should be:2386632445.036339, error:-10030.970906
20:34:07 T:4140 DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
20:39:39 T:3528 DEBUG: CDVDClock::Discontinuity - CDVDPlayerAudio::HandleSyncError2 - was:2744370640.788447, should be:2744360601.979409, error:-10038.809038
20:42:32 T:4140 DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
above is when freeze happens
Full log file DXVA
