Hi
I'm using Isengard RC 2 under Linux now (windows before) and use it with TVH. Sadly time shift still is kind of buggy (picture hangs when going back and forth).
I noticed that the pvr.hts is from may (2.1.8) and I would like to give a newer build a try - but there does not seem to be any deb file available.
Would someone be so kind to post how to build the plugin from source and make a deb-file from it (so that it is easy to remove if its not working) - theise.hard branch states version 2.1.15 being the newest.
Thx
Nice! I did not find that! I only found a i386 deb the day before yesterday.
Sadly doesn't work with Kodibuntu running trusty.
ppa:wsnipex/kodi-git
2.2.1 there
Thx, maybe that solves my issues !
(2015-07-19, 04:19)robo989 Wrote: [ -> ]ppa:wsnipex/kodi-git
2.2.1 there
Sadly Kodi doesn't start with that package :-(
(2015-07-19, 09:02)ichkriegediekri Wrote: [ -> ] (2015-07-19, 04:19)robo989 Wrote: [ -> ]ppa:wsnipex/kodi-git
2.2.1 there
Works fine for me on trusty...
Kodi 16 Alpha 1...
pvr-hts 2.2.1
tvheadend backend 4.1.360
Can you show me the output of "apt-cache policy kodi-pvr-hts"?
sure :-) but can't be found
xbox@ZBMC:~$ sudo apt-cache policy kodi-pvr-hts
[sudo] password for xbox:
N: Paket kodi-pvr-hts kann nicht gefunden werden.
neither to be installed
xbox@ZBMC:~$ sudo apt-get install kodi-pvr-hts
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
E: Paket kodi-pvr-hts kann nicht gefunden werden.
Does not work for me either...
Running Kodi 16 alpha 1, Tvheadend 4.1 and kodi-pvr-hts 2.2.1..
odoll can you open a new thread since your issue is unrelated to this thread.
To everyone else, I believe this is a tvheadend issue since it doesn't happen if you revert to a sufficiently old release. I think the "timeshift to RAM" option made things even worse than they were before.
is version 4.0.4-8 a sufficiently old release?
You peeps are all using the old pvr addon.
The one you need isn't an update.
Remove the old one, install the new one.
You want "kodi-pvr-hts"
Make sure it's in available in the repo you've added.^
There's no bug here!
