Full Version: help to remove bar
Hi
Could anyone point me in the right direction to removing the bar marked in below picture...
This will disable the navigation bar systemwide and not just in Logo view...
In includes.xml add <!-- on line 238 before <include so it looks like
<!-- <include name="Topbar">
then add
--> at the end of line 343 so it looks like
</include> -->
If you want to hide it in just Logo view add
<visible>!Control.IsVisible(59)</visible>
on line 240
Thanks! would never have found that Smile just disabled it in logo view looks very clean now!
and if i would like to disable this bar in shift and episode view aswell?
edit, no worries i got the logic no and disabled the topbar on views 57 and 502 aswell! thanks for your help
