Hi, I am using an Android NEO X8-H and I am running kodi 14.1 with no real troubles , apart from the occasional crash..
I read that kodi 15.0 fixes this so I downloaded this from the website,as I have always done.But it now says error "this package is not compatible with your device (arm vs x86)
It won't let me open anything, even the existing 14.1...
I have uninstalled and tried to start from scratch but it keeps saying the same error..
Please help
Download arm version, not x86
I feel a little silly for asking that now - many thanks
Hello.
I got the same error, dowloaded the arm version and still the same.
I AM using motorola xoom Android 4.2.2.
I try with old versions as 13 even 12.0 and had the same errror, thats dosent make se se.
Any sugestion?
(2017-01-07, 13:33)Duda ferreira Wrote: [ -> ]Hello.
Any sugestion?
You need Lollipop firmware to use Kodi.
Your old packages might also be corrupted or those Kodi's are only compatible with Android 4.4.
I have a Motorola Xoom with Android 4.1.2. It is not rooted. It will not update from 4.1.2. I was wanting to set this tablet up for Kodi. I found an older version of Kodi (14.2) and it still gave error. Surely there is an older version of XBMC or Kodi that I can use. Any suggestions for what I can use and where to download it from?
HELP: Kodi is incompatible with my MXq box 4.4.2 firmware. I had Jarvis 16.1 and it totally deleted everything so I thought I would upgrade to Krypton. So I deleted Kodi and now I am unable to download. I have tried all versions and nothing works. I have tried each ARM download and it still says incompatible. I have done research on youtube and google and have tried everything I could find.[/size]
(2017-07-17, 04:28)ZannerSky Wrote: [ -> ]HELP: Kodi is incompatible with my MXq box 4.4.2 firmware. I had Jarvis 16.1 and it totally deleted everything so I thought I would upgrade to Krypton. So I deleted Kodi and now I am unable to download. I have tried all versions and nothing works. I have tried each ARM download and it still says incompatible. I have done research on youtube and google and have tried everything I could find.[/size]
Kodi 17 Krypton need at least android 5.0
Only way to have kodi working on android 4.4.2 is to stay on Kodi Jarvis
