2015-03-24, 22:23
if this is not posted in the best place please move accordingly, thanks
noob skinners i recommend trying Brackets, it's easy to learn, made for web design but is working well for xml.
http://brackets.io
my brackets story if interested:
when i started experimenting with skinning i needed a text editor.
notepad++ was recommend here. i was mac only at the time so tried it in wine.
it was overkill for me and not at all mac like, i wanted to learn skinning not an app.
i then found textwrangler, it is fast easy to learn and worked well for what i needed, to learn.
recently i acquired an oldish laptop. i dumped windows 7 and installed ubuntu and i like it, but that's another story.
so now i needed a new text editor for ubuntu. same problem as before. everything i tried was overkill or lacked key features i used in text wrangler.
then i found brackets mentioned in a article somewhere.
it works on OS X, Windows and Ubuntu so i now am using it on my mac and my asus laptop.
i really like this software. i think i may even try learning HTML next.
users of full blown text editors such as notepad++ and emacs will not like this at all. but for a beginner or someone learning HTML it is a game changer.
it is still in development and is FOSS i believe.
the only thing is it is backed by adobe and i do not have fond feelings for them.
but hopefully they will not use it as bait drawing us in to the empire's control.
hope this may help some would be skinners out there.
http://brackets.io
