I am experiencing this bug, and I can reproduce it on my 3 Raspberry Pi's ... (this might not mean much as they are all configured the same).
if I add a video addon to my favorites (an addon that streams online content), and I try to open the streams associated with those addons via the favorite menu, they don't play at all, I can browse the streams by category (depending on the addon)... I can get to the steam itself, but when I try to play it, it does absolutely nothing... navigating and playing the contents of those addons via the addon menu in File mode or library works fine.
this is skin-independent, I can reproduce this in every skin I have tried.
... while troubleshooting, i've tried "tricking" addons into showing up in the programs menu by switching the <provide> tag from "video" to "executable" ... and the same issue occurs in the "my programs" page... video streams don't play, i've tried this with a bunch of streaming addons and they all behave the same.
im on openelec, v14.2
any help appreciated.
1) Look in /storage/.kodi/temp/kodi.log
2) Find the error message and from it determine the name of the addon that is causing the error
3) Search/post in the relevant addon support thread.
See
http://forum.kodi.tv/showthread.php?tid=222321 for an example.
(2015-03-25, 03:24)Milhouse Wrote: [ -> ]1) Look in /storage/.kodi/temp/kodi.log
See http://forum.kodi.tv/showthread.php?tid=222321 for an example.
this is not addon specific,... 95% of them do this.
Addons work fine themselves if they are run via the addon menu... the problem happens when you try to run them via the favorites menu ... so I don't think I should start making a thread in every single addon support thread ... I would have to create a dozen threads that are the same.
- there is no error message, nothing happens when a stream is selected
- this particular example is HGTV app ... but most do the same thing.
from what I can see in the log, it seems like instead of running the stream, it saves something locally ... its as if the "execute" function in the Favorites menu calls a different function then in the Addons/Video menu
Log:
PHP Code:
DEBUG: webserver: request received for /jsonrpc
07:26:31 T:1968836608 DEBUG: ------ Window Init (DialogBusy.xml) ------
07:26:31 T:1619579968 NOTICE: -->Python Interpreter Initialized<--
07:26:31 T:1619579968 DEBUG: CPythonInvoker(77, /storage/.kodi/addons/plugin.video.hgtv/default.py): the source file to load is "/storage/.kodi/addons/plugin.video.hgtv/default.py"
07:26:31 T:1619579968 DEBUG: CPythonInvoker(77, /storage/.kodi/addons/plugin.video.hgtv/default.py): setting the Python path to /storage/.kodi/addons/plugin.video.hgtv:/usr/lib/python27.zip:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/lib/python2.7/site-packages:/usr/lib/python2.7/site-packages/PIL:/usr/lib/python2.7/site-packages/gtk-2.0
07:26:31 T:1619579968 DEBUG: CPythonInvoker(77, /storage/.kodi/addons/plugin.video.hgtv/default.py): entering source directory /storage/.kodi/addons/plugin.video.hgtv
07:26:31 T:1619579968 DEBUG: CPythonInvoker(77, /storage/.kodi/addons/plugin.video.hgtv/default.py): instantiating addon using automatically obtained id of "plugin.video.hgtv" dependent on version 2.1.0 of the xbmc.python api
07:26:32 T:1644745792 DEBUG: webserver: request received for /jsonrpc
07:26:33 T:1968836608 INFO: CheckIdle - Closing session to http://mirrors.kodi.tv (easy=0x63c33ff0, multi=0x74c77db0)
07:26:33 T:1968836608 INFO: CheckIdle - Closing session to http://xty.me (easy=0x63c12290, multi=0x2727dc8)
07:26:33 T:1619579968 DEBUG: HGTV: getRequest URL:http://www.hgtv.com/shows/flip-or-flop/flip-or-flop-full-episodes-videos
07:26:34 T:1619579968 DEBUG: HGTV: Content Encoding == gzip
07:26:34 T:1636357184 DEBUG: webserver: request received for /jsonrpc
07:26:34 T:1735390272 DEBUG: WaitOnScriptResult- plugin returned successfully
07:26:34 T:1619579968 INFO: CPythonInvoker(77, /storage/.kodi/addons/plugin.video.hgtv/default.py): script successfully run
07:26:34 T:1968836608 DEBUG: Saving fileitems [plugin://plugin.video.hgtv/?fanart=%2fstorage%2f.kodi%2faddons%2fplugin.video.hgtv%2ffanart.jpg&mode=GC&name=Flip%20or%20Flop%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20&url=http%3a%2f%2fwww.hgtv.com%2fshows%2fflip-or-flop%2fflip-or-flop-full-episodes-videos]
07:26:34 T:1968836608 DEBUG: -- items: 13, sort method: 0, ascending: false
07:26:34 T:1644745792 NOTICE: Thread BackgroundLoader start, auto delete: false
07:26:34 T:1794110528 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x63ce6d70
07:26:34 T:1794110528 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode)
