(2015-06-25, 08:59)xbmckid2012 Wrote: [ -> ]A Question though.
Is it possible to add DECKED OUT to the list ..
To keep things simple I'm only grabbing current season shows with full episodes. Decked Out only has clips so it doesn't appear in in full episode indexes.
Thanks so much for this. Is it possible to add the Vanilla Ice Project?
And American Rehab Virginia?
And season 14 of Renovation Realities, which is this years?
(2015-08-10, 21:17)pa2471 Wrote: [ -> ]Hi,
The addon picks up its videos from here:
http://www.diynetwork.com/shows/full-episodes
If it's not there, it won't be in the addon. Of the shows you listed, I only see full episode videos for 'Renovation Realities', all of which are in the addon.
(2015-08-10, 22:11)learningit Wrote: [ -> ] (2015-08-10, 21:17)pa2471 Wrote: [ -> ]Hi,
Ok. Thank you. Si I'm assuming your other one, HGTV behaves the same?
(2015-08-16, 16:02)pa2471 Wrote: [ -> ]Ok. Thank you. Si I'm assuming your other one, HGTV behaves the same?
Not sure what you're asking, but if you mean does it just create shows out of thin air - no. Any legal addon only can give you what's available on the website.
(2015-08-16, 22:49)learningit Wrote: [ -> ] (2015-08-16, 16:02)pa2471 Wrote: [ -> ]Ok. Thank you. Si I'm assuming your other one, HGTV behaves the same?
No, I meant that if I go to the hgtv website and look for full free episodes, it would then have those a available?
If you are asking if the free full episodes on the hgtv website are also available on the HGTV video add-on, then the answer is yes. You can also install the add-on and compare them yourselves. If you need further support on the HGTV add-on, it has its own dedicated thread; this is not the right place to discuss it.
(2015-08-17, 01:34)pa2471 Wrote: [ -> ] (2015-08-16, 22:49)learningit Wrote: [ -> ] (2015-08-16, 16:02)pa2471 Wrote: [ -> ]Ok. Thank you. Si I'm assuming your other one, HGTV behaves the same?
It appears the DIY webpage has been revamped. I checked the DIY addon today and most of the full episodes have been moved or removed. Renovation realities is no longer on the addon.
(2015-10-03, 13:03)fruz Wrote: [ -> ]It appears the DIY webpage has been revamped. I checked the DIY addon today and most of the full episodes have been moved or removed. Renovation realities is no longer on the addon.
The content changes every month or so. What you see is what's available this month.
fruz is correct, the page has been revamped. now only the first video on the full episodes page shows up in the plugin, but if you scroll down there are plenty of full episodes you can stream from the website.
Big change to the website layout, I don't think the add-on works at all.
I'll get this fixed in a few days.
We appreciate the updates for this and HGTV. They are must have addons in our house
It looks like there's a problem with the 3.02 version. Had a similar problem with the HGTV add-on, which was fixed by installing the new 3.03 version from github. Any possibility of an update to the DIY add-on?
