Full Version: No "Enable joystick and gamepad support" option in menu
As it is my first post here, hello! Kodi is great, thank you guys for your hard work on keeping things like that.
Right now I am using Kodi on my Zotac CI320, which I bought to have personal server (torrentbox, ownCloud, file server, calendar syncing and so on) as well as HTPC (connected to my old TV). I did some research and found Kodibuntu. I decided I'd give it a try. It landed on Zotac and behaved quite handsomely, did all the things I expected it to do, but it tends to hang once in a while (every couple of days) without a trace in the logs (syslog). Since I am hosting ownCloud instance for a couple of people, this is both unacceptable and irritating. Since Kodibuntu is based on Lubuntu 14.04, it has rather old kernel and no systemd (I am a fan), I decided to move on to Fedora or openSUSE. There is a great tutorial on turning Fedora into HTPC (http://kodi.wiki/view/HOW-TO:Install_Kod...n_packages) which can be used with slight modifications on every systemd based system. I was able to get it all working like a charm, except for one thing - I don't have gamepad support. On Kodibuntu I used gamepad, which was fantastic way to control Kodi. Both on Fedora and openSUSE this option is missing https://imgur.com/a/jRfsq , even though my gamepad is properly detected by OS.
I know I am not the only person with similar problem (http://forum.kodi.tv/showthread.php?tid=...ht=gamepad and there are more similar topics) but I would like to solve it. The question is: how can I check, wether Kodi from Fedora (RPMFusion) or openSUSE (packman) has compiled support for gamepads? What should I write on Bugzilla so the packager would know how to fix this? Is there another possible explanation, maybe I should install some additional packages (I installed some additional kernel modules for Fedora, that provided XBox controller support without success)?
@uNiversal, thanks for your interest. Log is here: http://pastebin.com/PpfBRyjT
open a bug on opensuse. Ask them to enable joystick support ( --enable-joystick). This depends on SDL2 being available.
