2018-10-24, 15:19
2018-10-24, 15:29
2018-10-24, 17:24
Is this addon expected to work with Jarvis? I have 16.7.4 SPMC and it is not working for me. I will post an issue on github if this is expected to work for that version.
It did work fine for a brand new install of kodi 17.6
2018-10-24, 17:34
(2018-10-24, 17:24)tnkrer Wrote: [ -> ]Is this addon expected to work with Jarvis?
No, it's not. You can try to install v.2.2.2, its should work but it's not supported any more.
2018-11-09, 19:38
(2018-10-24, 15:19)Roman_V_M Wrote: [ -> ]https://github.com/xbmc/repo-scripts/pull/919Many, many thanks for this!
2019-02-02, 00:10
First many thanks Roman for your work, it's much appreciated.
Just one remark to improve the addon.
Currently, the search returns every subtitles listed in the addic7ed page, completed or not.
As it is not possible to download uncompleted addons, download returns an error, is it possible to add a feature to remove uncompleted subtitles from the search results ?
2019-02-02, 16:28
What are 'uncompleted' subtitles? Do they have any special indication on the site?
2019-02-02, 20:01
Hi @Roman_V_M , does your addon work differently from Amelandbor's? Amelandbor's is still working for me but I don't know if it's being maintained.
I'm wondering if I should switch to yours or "don't fix it if it's not broken".
2019-02-02, 20:23
You can have both simultaneously, as they have different addon-id's, and see for yourself.
It's free after all.
2019-02-02, 21:08
Uncompleted subtitles are subtitles that are showed on the addic7ed website but that are not yet finished.
There is an indication on the website. If you open a page for whatever tv episode, for each subtitles of the list you can see a mention "Completed" or "xx.xx%".
"xx.xx%" subtitles are not downloadable, the download button leads to a login page.
2019-02-02, 21:26
(2019-02-02, 20:23)host505 Wrote: [ -> ]You can have both simultaneously, as they have different addon-id's, and see for yourself.Thanks for the suggestion, just installed it.
It seems to search slightly slower than Amelandbor's but could just be anecdotal.
2019-02-03, 01:38
(2019-02-02, 21:08)Spudufion Wrote: [ -> ]Uncompleted subtitles are subtitles that are showed on the addic7ed website but that are not yet finished.Yes, now I remember a similar discussion by email. You cannot download partially translated subs without being logged in . But you can actually login to the site in the addon settings. And I'll see what I can do.
2019-02-03, 03:40
Thanks a lot !
2019-02-05, 08:17
It's just me or the site is down the last couple of days?
2019-02-07, 06:32
Yes, it was. Today, it seems to be fine.
