Full Version: Music: Display album art as visualisation?
I'm running Kodi on an AFTV (Android) but I'm sure this will apply to any OS.
When playing music in full screen, or visualisation, mode, I'd like to see the album cover, either from the embedded image or from within the album folder, displayed full screen with the music info OSD overlaid.
I can almost do it by activating full screen, which displays the track details and small album art, but it disappears quickly. Even if I could maintain the small album art and music info would be a start.
Any way to set this up?
What is shown depends on the skin - so you could check different skins (I use Experience1080 and it shows the cover and if selected background artist image with overlayed viz).
@ "FireInMyHole"
Press I
(2015-03-29, 13:06)mbuzina Wrote: [ -> ]What is shown depends on the skin - so you could check different skins (I use Experience1080 and it shows the cover and if selected background artist image with overlayed viz).
I had a look at that, found the visualisations options, but couldn't get it to just display the embedded album art. What settings do you have?
(2015-03-29, 13:47)k4sh1n Wrote: [ -> ]@ "FireInMyHole"
Press I
Do you mean "info" on the remote keymap?
Just the album art is not an option, that is true. In that case you would need to modify the skin.
(2015-03-29, 16:04)FireInMyHole Wrote: [ -> ]
Press I
Yup, prevents it from disappearing.
(2015-03-29, 19:01)k4sh1n Wrote: [ -> ]
Press I
But the album cover is so small relative to the rest.
(2015-04-05, 21:25)ntropy Wrote: [ -> ]
(2015-03-29, 16:04)FireInMyHole Wrote: [ -> ]Do you mean "info" on the remote keymap?
