This is the current section on bit depths:
Native Display Bit Depth
The chosen display bit depth is the bit depth madVR will dither to. This setting is found in
devices -> properties -> the native display bitdepth is. It should be noted madVR processing is done at 16-bits, so the difference in output bit-depths can be difficult to differentiate when choosing between dithered 8-bit and 10-bit.
10-bit output requires two settings are enabled in madVR's
general settings.
fullscreen exclusive mode must be enabled. And the checkbox
use Direct3D 11 for presentation (Windows 7 and newer) must be checked.
Typically, TVs supporting UHD resolutions also support output bit depths of 10-bits or more, but this is not always the case. Many olders TVs are also native 10 bit panels. To confirm 10-bit output is received, the following
test protocol can be undertaken.
The choice of bit depth determines the number of available shades of each color. This is best demonstrated by the two industry standard color gamuts:
rec.709 & rec.2020.
Rec. 709 - Output at 8-bits (256 colors), common to current 1080p Blu-ray.
Rec. 2020 - Output at 10-bits (1,024 colors) or 12-bits (4,096 colors), common to current UHD standard.
An 8-bit (Rec. 709) source cannot be expanded to a new gamut. Rather, the number of shades or steps between each color is increased allowing an additional 2-bits of precision. This means madVR adds less dithering to the image. The result is less noise and smoother gradation from one color to the next. 10-bit (Rec. 2020) sources are the only sources that truly benefit from 10-bit output by preserving the expanded gamut contained within the source.
Be careful when selecting 10-bit output with an 8-bit panel. Additional dithering will be added to the image by the GPU at output, reducing image quality. It is always a safe bet to set madVR to 8-bits if the panel bit-depth is unknown.
the bit deep output doesn't change the colorspace it is still BT 709 with a BT 709 source with default settings.
10 bit is a recommended for BT 2020 but you can still display it with 8 bit or even lower bit deep.
that's why i like to say you don't get more different color you get more steps between each color. 8 bit green 256 and 10 bit green 1024 are still 100 % the same color.
and you get float point math from converting YCbCr to RGB so there is now kind of over 10 bit data available. the difference for bt 709 is not really worth it.if you take into a count no plasma can even do 8 bit (they are kind of different and that's why they are more noisy than they should be) and most screen are 8 bit only. so don't put to much time into this. this get's important with the UBD.
(2015-10-27, 04:35)Talguy Wrote: [ -> ]@ionutm80, when you're playing a movie what profile in the Madvr config window is highlighted in bold font? one of the three your created or one of the DSPlayer ones?
(2015-10-27, 05:59)Warner306 Wrote: [ -> ] (2015-10-27, 03:58)ionutm80 Wrote: [ -> ] (2015-10-26, 18:52)Talguy Wrote: [ -> ]@ionutm80, Do you have any of Madvr's zoom options active?
Hi, no zoom options checked in madVR. As said this does not happen in mpc-hc. What is also very strange is that in spite of the fact that I set Kodi to load from active madVR profile it still created its own profile in madVR settings ignoring what I have already set there. For ref. I had 3 profiles for 1080p, 720p and SD movies am now I have a 4th one called DSPlayer ... I'm lost.
You probably set Kodi to create internal tables and played a video once and don't know it. Delete this dummy profile and see if it is replaced. This has happened to me before.
Hi, coming back with a feedback. I have deleted all madVR profiles created by DSPlayer and you were right: I tried to play a movie before remembering to set "load from madVR active profile". But ... the problem remained. So I started to take it on a step-by-step approach and also tested on a weaker system with only 1 madVR profile, an Intel NUC with Core I3 4010u. To my surprise immediately after I disable SVP, everything went butter smooth with Kodi + active madVR profile, I could even check Smooth Motion ON and the NUC was still holding with 0 dropped frames. It seems that there is a problem when Kodi fullscreen interacts with SVP after the former starts to interpolates frames up to 59.94 (TV resolution is 60 and movies are all blu-ray rips at 23,976).
And it's not a problem of resources, I put 1g profile in SVP and tweaked madVR to only use DXVA scalling for everything including chroma. In MPC-HC GPU load is about 40-50% and CPU load varies between 65-85% load, perfectly stable. In Kodi after the strange zoom takes place the CPU is sky rocketing to 95-99% and I get warning messages from SVP. I haven't changed anything in Kodi settings except for the 3 files in DSPlayer folder given by a user from SVP forum: filtersconfig.xml, mediasconfig.xml and shaders.xml. I have attached some print screens of these files, Is there something that should not be there? Or is wrongly set?
Thanks a lot in advance for feedback.
dsplayer config files
Is it possible to have the DSPlayer setting in kodi 'Manage settings with Kodi'' changed to read something like 'Interaction with madVR'? This setting has some current implications I have brought up in the madVR thread (
http://forum.doom9.org/showpost.php?p=17...ount=33948) and its not very clear from the current label used in kodi what this setting is doing until you select it.
It may be advisable to look again what the best default option is for this setting or to expand the workings of the current default option 'Load and save with DSplayer database' so it also imports changed settings into the database from madVR if any of its profile settings have been changed from within madVR itself.
(2015-10-28, 12:03)ionutm80 Wrote: [ -> ] (2015-10-27, 04:35)Talguy Wrote: [ -> ]@ionutm80, when you're playing a movie what profile in the Madvr config window is highlighted in bold font? one of the three your created or one of the DSPlayer ones?
(2015-10-27, 05:59)Warner306 Wrote: [ -> ] (2015-10-27, 03:58)ionutm80 Wrote: [ -> ]Hi, no zoom options checked in madVR. As said this does not happen in mpc-hc. What is also very strange is that in spite of the fact that I set Kodi to load from active madVR profile it still created its own profile in madVR settings ignoring what I have already set there. For ref. I had 3 profiles for 1080p, 720p and SD movies am now I have a 4th one called DSPlayer ... I'm lost.
I recommend using your own TVs interpolation system and play at 24Hz if you want "Smooth" motion.
Older TVs can have issues, with either frameskip or artifacts.
(2015-10-28, 15:30)Razoola Wrote: [ -> ]Is it possible to have the DSPlayer setting in kodi 'Manage settings with Kodi'' changed to read something like 'Interaction with madVR'? This setting has some current implications I have brought up in the madVR thread (http://forum.doom9.org/showpost.php?p=17...ount=33948) and its not very clear from the current label used in kodi what this setting is doing until you select it.
This seems pretty clear to me. What are you confused about?
- Manage settings with Kodi
These settings determine the way madVR settings are managed:
Never: The Kodi madVR GUI is disabled and all madVR settings are loaded exclusively from the madVR control panel.
Load and Save with DSPlayer database: Enabling this option allows basic configuration of madVR from within Kodi. These settings are accessed during video playback by selecting
Video Settings. Video settings are set on a per video basis but can be saved as a global profile for all videos. DSPlayer will create its own
DSPlayer Profile Group in the madVR control panel when this setting is enabled. This is a dummy profile intended to separate DSPlayer settings from existing madVR profiles. This dummy profile is not meant for external configuration. Internal settings tables are saved by Kodi – no settings are saved in the madVR control panel.
Load from madVR active profile: Upon playback, the appropriate profile is loaded from madVR for the selected video. Changes made from within Kodi will change the same value in the madVR control panel. No dummy profile is created. These changes only impact the active madVR profile and profile rules cannot be created or saved. This is the best choice for those who have set-up profiles in madVR. Any changes made to the active profile are saved externally by madVR. External settings are always loaded in place of internal Kodi tables.
Load and Save with DSPlayer database puts a dummy profile in madVR so you can't edit settings externally. Load from madVR active profile makes it possible to make changes from Kodi or madVR. The result is saved in the profile created in madVR.
What else do you want it to do?
(2015-10-28, 10:01)huhn Wrote: [ -> ]the bit deep output doesn't change the colorspace it is still BT 709 with a BT 709 source with default settings.
I incorporated this explanation in some form. Thanks.
Warner306.
You need a screenshot looking from the menu before without the description at the bottom to understand the point i'm trying to highlight..
The available options in that setting are very straight forward and well described from their headers but the original title of 'manage settings with kodi' is not. When your looking down through the list of options in the DS player menu where it is placed it is not apparent it is something related to madVR until you mouse over it (especially when the default setting of 'Load and Save with DSPlayer database' is shown to the right of it). From the title one thinks its more about integration between DSplayer and kodi than anything related to madVR. Do you see what I mean?
I feel it would make for more sence and be more understanding / user friendly if there was reference to madVR in there to make it more apparent to users. Another example of a replacement text would be;
'madVR setting handling'
So the entire line with default setting would say...
' - madVR setting handling' 'Load and Save with DSPlayer database'
That accurately describes what this setting does in three words, 'Manage settings with Kodi' does not make sense on its own what this setting is doing. When you know all the sub settings it makes a little more sence but not much.
Sorry, another noob question. With Kodi DSPlayer set up if I play a video it seems I cannot see the kodi player gui overlay, if i hit 'info' for example? Is it possible to have the kodi gui player controls/info window etc available when using dsplayer?
(2015-10-28, 22:55)Razoola Wrote: [ -> ]You need a screenshot looking from the menu before without the description at the bottom to understand the point i'm trying to highlight..
Agreed: "Manage madVR settings with Kodi" would be better.
(2015-10-28, 22:58)jdoo Wrote: [ -> ]Sorry, another noob question. With Kodi DSPlayer set up if I play a video it seems I cannot see the kodi player gui overlay, if i hit 'info' for example? Is it possible to have the kodi gui player controls/info window etc available when using dsplayer?
The GUI should be visible when you play anything. The madVR settings window is hidden under the icon for Video Settings. Nothing can be done about that.
You can create a direct shortcut to Video Settings by adding an entry to your keyboard.xml (keymap):
<keymap>
<FullScreenVideo>
<keyboard>
<home>ActivateWindow(123)</home>
</keyboard>
</FullScreenVideo>
</keymap>
"home" is an example key. You can change this to any key of your choice.
(2015-10-28, 23:29)Warner306 Wrote: [ -> ]Agreed: "Manage madVR settings with Kodi" would be better.
Yes, that would work too.
Is it worth waiting for a reply to a question I asked several days ago ?
