I have a new htpc here with Intel 6100T (HD 530 graphics) and a very strange issue.
Randomly every 1-3 minutes there is ~5 frame drops when using madVR. Kodi EVR is fine.
Avg rendering time in a 24p 1080p movie is ~2ms. Max rendering time is ~7ms.
After tweaking literally everything (BIOS, drivers, Windows, madVR) issue still persists.
Now turning on debugging in Kodi gui seems to resolve the problem.
Avg rendering is still ~2ms. Max rendering comes down to ~2ms and there are no frame drops.
What is debugging doing besides writing to the log file and putting stats on the screen?
What is happening?
(2016-08-16, 09:04)anty Wrote: [ -> ]I have a new htpc here with Intel 6100T (HD 530 graphics) and a very strange issue.
What is happening?
Found log settings in
advancedsettings.xml
Unfortunately with disabling text on screen (level 1) issue comes back. So the workaround is not good.
Hey,
Im using kodi 16.1 jarvis with DSplayer, LAV filters, Xysubfilters and madVR. Whenever i play a video it gets zoomed and i can only see 1/4 of the picture. If i use windowed mode it works.
Debug log:
http://pastebin.com/Ldje1qU5
I have tried:
- Fullscreen exclusive mode disabled in kodi
- Hardware acceleration off
- Uninstalling Reclock
Another problem im experiencing is when i open the property page for all the internal filters it doesnt show everything.
Picture:
http://imgur.com/a/lkKEF
Thank you in advance guys!
(2016-08-17, 11:41)blackbanana Wrote: [ -> ]Hey,
Debug log: http://pastebin.com/Ldje1qU5
I have tried:
Picture: http://imgur.com/a/lkKEF
You have increased the desktop zoom. That is why you can't see the entire dialog. This is probably a bug in DSPlayer. I don't know how to fix it without disabling the zoom.
Does MPC-HC work or does it also show the same problem? Try accessing video settings during playback to see if the zoom settings there have changed.
(2016-08-17, 22:08)Warner306 Wrote: [ -> ] (2016-08-17, 11:41)blackbanana Wrote: [ -> ]Hey,
I have tried:
For me this happens if I have previously defined 720 (24, 50, 60) as part of my TV resolution (that in fact, accept). The only way I have been able to make it work is just delete them, and only define the 1080 resolutions. Then the image is perfect no matter what.
(2016-08-17, 23:33)vicmanpergar Wrote: [ -> ] (2016-08-17, 22:08)Warner306 Wrote: [ -> ] (2016-08-17, 11:41)blackbanana Wrote: [ -> ]Hey,
I have tried:
I had this same problem. I defined my monitor resolution for the TV resolution and got the oversized bit when playing dsplayer.
Hello guys,
I need some help! I'm using Kodi 16.1 with dsplayer in combination with svp. (smooth video project) This is working great for local files and internet streams but with live TV I'm getting an error. With dsplayer disabled it is working.
So I want to use dsplayer for local files and streams, and DVD player for live TV. I know I can set some Merritts in dsplayer settings, but I have no idea what kind of rule I need to add..
Has anyone an idea? I'm using dvblink for live TV..
Cheers,
Marcel
I have tried:
If you mean my desktop zoom in windows its set to 300% (default). I tried decreasing it to 100% but i still got the zoom problem in kodi and i cant have it on 100% anyway since my resolution is 3840x2160 and everything is to tiny at 100% zoom. If i press "\" button twice in kodi it works. But i would rather like it to work normally when i play a video without having to press "\" everytime i want to watch something.
IMAGE:
http://imgur.com/a/zje6j
I would rather use DSplayer. But i will try with MPC-HC.
so your not using full screen you have it in a window? as i have my XBMC at 4k res and all my movies play at 100% in dsplayer
Maybe a bit more information? ?
I have tried:
Unbelievable it worked! Thank you!
Image:
http://imgur.com/a/32TH9
Should i use these displaymodes or should i add some more refresh rates?
(2016-08-18, 11:54)blackbanana Wrote: [ -> ] (2016-08-17, 23:33)vicmanpergar Wrote: [ -> ] (2016-08-17, 22:08)Warner306 Wrote: [ -> ]You have increased the desktop zoom. That is why you can't see the entire dialog. This is probably a bug in DSPlayer. I don't know how to fix it without disabling the zoom.
Image: http://imgur.com/a/32TH9
You should add 2160p23 and 2160p59. And you can access any option in LAV Filters or XYSubFilter by remote.
If you want, you can leave display modes empty and have Kodi change refresh rates. This found in Video -> Playback.
(2016-08-18, 22:12)Warner306 Wrote: [ -> ]If you want, you can leave display modes empty and have Kodi change refresh rates. This found in Video -> Playback.
Last I tried, Kodi's own refresh rate changing didn't work well with variable frame rate videos shot on a smartphone. When frame rates momentarily dipped very low, Kodi would erroneously proceed to change the refresh rate before realizing the refresh rate indeed should NOT be changed.
This refresh rate lottery resulted in an accompanying distracting black screen flash. In fact, this was the final deciding factor for me to switch to madVR/dsplayer and I've NEVER had a similar problem since!
(2016-08-18, 22:08)Warner306 Wrote: [ -> ] (2016-08-18, 11:54)blackbanana Wrote: [ -> ] (2016-08-17, 23:33)vicmanpergar Wrote: [ -> ]For me this happens if I have previously defined 720 (24, 50, 60) as part of my TV resolution (that in fact, accept). The only way I have been able to make it work is just delete them, and only define the 1080 resolutions. Then the image is perfect no matter what.
Thank you for your help!
I added 2160p23 and 2160p59 and its working properly.
Do you have any solution to the other problem? As you can see.. I cant see all the options in property page.
Can i change these settings from anywhere else?
Image:
(2016-08-19, 09:56)blackbanana Wrote: [ -> ] (2016-08-18, 22:08)Warner306 Wrote: [ -> ] (2016-08-18, 11:54)blackbanana Wrote: [ -> ]Unbelievable it worked! Thank you!
Image: http://imgur.com/a/lkKEF
All of the settings can be changed by remote from DSPlayer settings. Just select any of the filters and all the options should be there. You don't have to open the property page.
