(2016-08-29, 11:13)JoshDi Wrote: [ -> ] (2016-08-27, 11:55)ashlar Wrote: [ -> ] (2016-08-12, 16:39)JoshDi Wrote: [ -> ]can someone send me the link to the github for the latest source code of Kodi DSPlayer? I want to see I can take over the project... thanks
JoshDi thanks so much for trying. I don't know if your efforts will prove successful but knowing that somebody is at least trying to pick up the torch gives us some hope.
Thank you!
Havent had much luck merging the branches but still trying
Any news about this?
I've actually started to look for alternatives now.
(2016-09-17, 09:02)Stefanseiner Wrote: [ -> ] (2016-09-16, 12:24)stoolzo Wrote: [ -> ]Hi, all DXVA decoding is broken on all RX cards, i've been trying to get some TECH sites to pickup on this but nobody seems to care that the new RX cards cant hardware decode H264 or H265.
I can't agree with you because with MPC and LAV my RX 460 can handle h.264 and h.265 fine @ 4k in hardware, see few posts above.
I find that hard if not impossible to belive, this is a well documented problem, I think you'll find your CPU is doing all the work for H264 and you probably have one of the driver versions installed that works with H265, my H265 was working initially but H264 has never worked.
The latest drive seems to break both.
If you insist your's is working by all means provide proof as if this is the case people must have faulty cards.
(2016-09-18, 17:12)stoolzo Wrote: [ -> ] (2016-09-17, 09:02)Stefanseiner Wrote: [ -> ] (2016-09-16, 12:24)stoolzo Wrote: [ -> ]Hi, all DXVA decoding is broken on all RX cards, i've been trying to get some TECH sites to pickup on this but nobody seems to care that the new RX cards cant hardware decode H264 or H265.
ok, so it turns out that in some cases the RX can hardware decode H264, I was wrong, it seems to have no issues with basline profiles encoded movies at any bitrate but struggles with high profile 4.1 encloded movies at bit rates 30mb/sec or higher. My 5 year old piece of crap 7650 can do this no problem.
Mpc be and madvr with lav work fine. It's just finding a remote that Is a pain.
that depends on what GFX card you are using and how you movies were encoded, see my previous post....
If you are looking for a cheap HTPC remote this one is stupid good as it has keybaord functionality on both sides and 5 IR programable keys so you can control volume on your amp through HDMI-CEC, power, hell I even have my LED lights setup on it.
This tiny little remote does everything. I also also mapped the windows volume and mute keys to other tasks, i'm using every button on it, its great for just sitting in front of your HTPC browsing the internet or controlling KODI or MPC.
Tip - create a batch file to kill MPC.exe and map this to a key, otherwise you have to click exit on MPC every time you stop movie. PM me for more advice.
http://www.ebay.co.uk/itm/CF615-iPazzPor...SwOVpXcYEV
(2016-09-20, 14:17)robl45 Wrote: [ -> ]Mpc be and madvr with lav work fine. It's just finding a remote that Is a pain.
Harmony remotes work well in controlling Kodi and MPC.
I hit stop and it goes back to kodi without issue. Need a remote that controls kodi and Mpc. That's the main issue. Otherwise media center remote is option but I haven't tried. This would be great if there was developer
You talking with or receiver? I'd ideally like wifi but anymote has kodi as do others but most don't have mpchc. Remoteextender makes kodi remote work for mpchc but I can't get it working.
(2016-09-20, 18:54)Warner306 Wrote: [ -> ] (2016-09-20, 14:17)robl45 Wrote: [ -> ]Mpc be and madvr with lav work fine. It's just finding a remote that Is a pain.
Yatse for Android is supposed to handle Kodi and MPC-HC
Yatse works quite well. Unfortunately it doesn't integrate into other remotes. Been using it for years
I looked at Irule, it seems much more complicated than anymote or the harmony hub.
I guess it is. Actually irule starts as blank, and you have to build from scratch your remote control screens and buttons, macros, etc.
It's complicated but very effective and customizable. Once it's operational, nothing can't beat it
the problem I find with all controller apps is you cant just pick it up and use it, you have to unlock your phone, open the app, wait for it to connect, then use it, a standard remote it far better as you never need to look at it, after a while you remember where the buttons are by touch. The remote I posted is defo the best of both words, PC / MOUSE and IR controller, all for £15.
I do also use an app for me Denon receiver but only when I want to dig deeper into the settings.
