(2017-09-04, 19:19)Kolabor Wrote: [ -> ]@aracnoz: Good to see You back. Does Your new build contains this fix by RickDB? Sadly I don't see it in there and without this fix Kodi will crash on every MKV file that has chapters with empty chapter names.
(2017-09-04, 19:30)RickDB Wrote: [ -> ]@aracnoz: Glad to see you're back
@Kolabor: Different fix in there but same result (tested with that 15s clip).
(2017-09-04, 19:41)Kolabor Wrote: [ -> ]Oh Great! Will test it in a moment.
sorry guys I'm quite busy in these days and I had no chance to read the last posts, I only posted the update
there was problems that I fixed in chaptersmanager some weeks ago, I think that the problem should be the same posted here
https://forum.kodi.tv/showthread.php?tid...pid2629760
anyway thx for testing
(2017-09-04, 16:58)aracnoz Wrote: [ -> ]Update: DSPlayer 17.4 Krypton
04 September 2017 (x86-da9656c) (x64-89977ed)- Added OSD label to show the active decoder name while playback (d3d11, dxva2, native, direct, copyback...) (DialogProcessInfo "o")
- Added internal Sanear option to ignore system channel mixer
- Updated internal Sanear to v0.3 (DSPlayer build 017973c)
- Updated internal LavFilters to v0.70.2.67 (DSPlayer version)
- Updated internal LavVideo OSD to support D3D11 hardware decoding, hardware device / codecs / resolutions
- General improvement for internal LavFilters OSD
- Fixed internal LavAudio OSD MixingLayout
- Fixed EVR Pixel Shaders
- Fixed DSPlayer playing videos from FTP
- Fixed ChapterManager could crash with an empty chapter name
- Merged with the official Kodi 17.4 Krypton Final
Thank u so much my friend!!
Thanks aracnoz for not leaving us alone.
(2017-09-04, 21:13)aracnoz Wrote: [ -> ] (2017-09-04, 19:19)Kolabor Wrote: [ -> ]@aracnoz: Good to see You back. Does Your new build contains this fix by RickDB? Sadly I don't see it in there and without this fix Kodi will crash on every MKV file that has chapters with empty chapter names.
there was problems that I fixed in chaptersmanager some weeks ago, I think that the problem should be the same posted here https://forum.kodi.tv/showthread.php?tid...pid2629760
Yes. The problem is fixed.
(2017-09-05, 17:28)ashlar Wrote: [ -> ] (2017-09-04, 16:58)aracnoz Wrote: [ -> ]Update: DSPlayer 17.4 Krypton
I second that. Thanks a lot aracnoz!
I have an intermittent issue where I start to play a file, MadVR changes the refresh rate, then nothing happens. Kodi says the file is playing (it has a little play icon next to it) but it's not. I have to press stop and then try again until it works. I looked at the logs but they don't show any difference between when it works and when it doesn't. Has anyone else had this problem?
Also thanks for the 17.4 update. DX11 decoding is awesome, so much faster on my weak machines. Hopefully it'll support deinterlacing soon and it'll be usable on my HTPC!
MLB.tv doesn't play with Kodi DSPlayer. It says error check the log and this is what I get...
Quote:20:56:12.157 T:23596 DEBUG: CWinEventsWin32::WndProcWindow is active
20:56:12.157 T:23596 DEBUG: CSettingsManager: requested setting (dsplayer.exclusivemodeevr) was not found.
20:56:12.157 T:23596 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\System32\notepad.exe
20:56:14.112 T:23596 DEBUG: CWinEventsWin32::WndProcWindow is active
20:56:14.112 T:23596 DEBUG: CSettingsManager: requested setting (dsplayer.exclusivemodeevr) was not found.
20:56:16.012 T:23596 DEBUG: CWinEventsWin32::WndProcWindow is active
20:56:16.012 T:23596 DEBUG: CSettingsManager: requested setting (dsplayer.exclusivemodeevr) was not found.
Any idea how to fix this dsplayer.exclusivemodeevr was not found issue?
oldpainless.
with your gtx 1080 Ti which mode you prefer to put for contained in 4K among those provided by aracnoz .
to days I have a video card GTX 1080 Ti.
in your opinion which of the two it's more indicated for a better one video quality.
so to have D3D11 Native (and to see DX11 in madVR) you have to select
- Hardware Decoder to use: D3D11
- Hardware Device to use: Automatic (Native)
for D3D11 Copy-Back you have to select
- Hardware Device to use: <specific hardware device from the drop list menu> (in your case the 1080ti)
(2017-09-06, 10:32)gotham_x Wrote: [ -> ]@oldpainless.
D3D11 Native seems to give the biggest & best bang for the buck.
K
Awsome, Kodi with Lav Filters and Madvr is amazing!!
One thing though, maybe someone has an answer to why the player info (codec info thing or what ever it´s called)
says that a dts hd master stream is only dts?
**Screenshoot***
https://drive.google.com/open?id=0B781WQ...jJ5MW13NUE
