2018-03-13, 23:31
O
If you are not upscaling a video (such as a 4k UHD rip shown at 4K UHD), then image upscaling won't activate as it is unnecessary. The only required scaling is chroma upscaling to alter the chroma subsampling applied to the source. Try a 1080p rip scaled to 2160p. Despite common belief, 1080p rips are more demanding than 720p rips when scaling to 4K. That is a true stress test. I bet you won't be able to go beyond NGU medium luma doubling. Again, always worry about luma doubling and set everything else to "let madVR decide." High quality luma scaling is what makes madVR's image upscaling special. Chroma is a waste or overkill to most human eyes. The chroma layer is simply too soft and lacks detail. Luma, luma, luma.
When upscaling, it can be helpful to make profiles for each resolution and resolutions combined with the source frame rate. Each resolution and frame rate combination will require different settings if you are maximizing your graphics card. As stated, every source presents a different load on the GPU. So you want profiles to adjust for each scenario.
I highly recommend you read the set-up guide below. I wrote it. It has not been updated for any new features, but everything else is up to date. I am missing custom refresh rates, reduce compression artifacts and reduce random noise. Turn off reduce ringing artifacts, reduce compression artifacts and reduce random noise unless you are watching torrented TV shows. Blu-ray rips or files over 10 GB shouldn't have these problems. So there is no need to destroy the image. Debanding is another story. Many 1080p Blu-rays have some banding. And debanding is not very destructive. I recommend it for any profile below 4K. You should only alter the source in subtle ways if it is high quality to begin with. NGU chroma/luma and you are good to go in most scenarios.
madVR Set up Guide (for Kodi DSPlayer and Media Player Classic)
(2018-03-13, 14:57)mkohman Wrote: [ -> ]Sorry to have started an argument between the two of you but I would like to confirm that I have received my Sapphire RX560 4GB and its working like a charm.. No hick ups whatsoever and running on the highest settings of MadVR as shown in pictures below (JAVS Settings from AVS Forums) .. Thanks for your help guys [emoji106]You have some questionable settings and some apparent settings confusion based on those posted screenshots. For starters, there is no way your card can do NGU very high luma doubling. You would need a 1080 Ti for that. And even that might choke. With your card, NGU low or medium would be appropriate. Set everything else to "let madVR decide." Then you will use madshi's preferred settings for each upscaling scenario. This is like using expert settings. He knows what he is doing, so "let madVR decide." Otherwise, you may waste resources on settings that do very little to improve image quality.
