Full Version: KodiBuntu updates on a Dell Mini 9
Morning all,
I have a bit of a problem, which I'm guessing is an easy fix for people with more linux experience than myself.
I have a Dell Mini 9 running KodiBuntu purely for the purpose of updating the library (I have 8 RaspberryPi's and none of them enjoy updating the library and playback at the same time)
I've installed KodiBuntu 32bit which is the 14.0rc, trying to update it to 14.2 using sudo apt-get update then upgrade. It says "The following packages have been kept back" which includes Kodi.
If I do a sudo apt-get update kodi, it updates all the way to 15.0 Alpha....
I'm positive its something simple I'm not doing correct if someone could let me know it would allow me to keep my hair for that little bit longer.
Thanks,
remove the unstable ppa, add the stable ppa, then update.
http://kodi.wiki/view/HOW-TO:Install_Kodi_for_Linux
Worked perfectly, thanks wsnipex
