2015-04-03, 11:24
I have a Minix X8H-Plus box. The system comes pre-installed with a custom Minix version of Kodi, but it is based on Gotham and therefore I can't get it to see my centralized MySQL database of movies, music, etc (I also have Windows clients on my network).
Therefore, I'd like to use Helix on my Minix, but there is one file type that refuses to play correctly. The problem files in question are Recorded TV recordings that are 25 fps (Australian TV). For some strange reason reason, Helix Kodi refuses to 'acknowledge' the 25 fps frame rate of the files, and instead implements a ~40 fps frame rate which makes the video impossible to watch (massive skipping). This only happens with files recorded from one particular tv channel, and also the live tv streams from the same channel. Turning on "Adjust refresh rate to match match video" makes no difference at all.
After much trial and error, I've worked out that the problem meg2 files play as expected if Hardware acceleration is turned off (i.e. if software acceleration is used), or if the amcodec (under HW Acceleration) is turned off. If I turn off the stagefright or mediacodec codecs (or both) the files still don't play correctly. However, if I turn off hardware acceleration or the amcodec, then my HD h264 files stutter terribly.
As such, my question is, is there a way of turning off hardware acceleration only for one file type? Alternatively, can I turn off the amcodec just for meg2 files, but have everything turned on for all other files types?
I've tried every combination with Helix, Isengard and SPMC - no joy.
Rich
Rich
