2015-04-04, 15:06
Hi all,
I am experiencing a problem with my raspberry pi 2
I have openelec on it on a class 10 Adata microsd card. Every time I shutdown the box the card gets corrupted. I always use the shutdown command built in Kodi and wait 20-30 seconds. I can't boot again afterwards...
I am really pissed about it.
The card is OK, I tested it on a windows pc with mini partition manager (or something like that,); surface scan shows no bad block.
Any ideas? Would I be better off booting from USB? Is there a definitive guide?
Are Adata cards really bad for use in a raspberry? What cards are you guys using?
Too many questions, I know!
EDIT:
Forgot tomention that I power the thing using a 5V 4A brick AND
It reboots fine, no problem, only shutdown, power cord unplugged and replugged causes it to corrupt.
EDIT:
