I am using xbmcbuntu with an Intel NUC. I have been trying to install mythtv backend and now I cannot log back into Kodi (there is no Kodi option on the top right - just the xbmcbuntu). Any suggestions how to fix this?
Cheers
Can you run Kodi from the desktop environment?
Do you mean via the terminal? How do you do that? (I'm using xterm for the terminal and it doesn't seem to launch anything if I just type the name in, e.g. kodi, xbmc, firefox, chrome - it just says "command not found")
sudo apt-get install kodi
That did the trick! Many thanks
