Full Version: switched to 1080 tv and now it crashes when i try to load
So I am running kodibuntu and previously had it on a 720 tv, I switched tvs and now it hangs every time it finishes booting and attempts load the gui. If i let it boot up without the tv plugged in it loads completely but once I plug in the tv it crashes.
system stats - http://pastebin.com/bdi1RQau
crash log - http://pastebin.com/awbgHDsc
kodi.old.log - http://paste.ubuntu.com/10741656/
dmesg - http://paste.ubuntu.com/10741683/
syslog - http://paste.ubuntu.com/10741686/
lspci - http://paste.ubuntu.com/10741746/
dmidecode - http://paste.ubuntu.com/10741766/
sysctl - http://paste.ubuntu.com/10741772/
Xorg.log - http://paste.ubuntu.com/10741853/
Please if anyone has any ideas please help :|
system hardware stats
1 x AMD A6-5400K Trinity Dual-Core 3.6GHz (3.8GHz Turbo) Socket FM2 65W AD540KOKHJBOX Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD 7540D
1 x ASRock FM2A88X-ITX+ FM2+ / FM2 AMD A88X (Bolton D4) SATA 6Gb/s USB 3.0 HDMI Mini ITX AMD Motherboard
2 x G.SKILL Ripjaws X Series 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9S-4GBXL
1 x SanDisk SDSSDP-128G-G25 2.5" 128GB SATA III Internal Solid State Drive (SSD)
1 x In Win BP671 mini ITX case with Haswell Ready 200W power supply, 8cm Fan, Black, TAC 2.0, Front USB 2.0X2, HD audio
bump
Remove your addon repositories. (mv ~/.kodi ~/kodi-bak)
fritsch,
Thank you for responding, i did as you instructed.
unforunately it still crashed immediately when after the kodi load screen. I have updated the new logs below
core - http://paste.ubuntu.com/10744436/
syslog - http://paste.ubuntu.com/10744454/
dmesg - http://paste.ubuntu.com/10744455/
kodi.old.log - http://paste.ubuntu.com/10744460/
kodi.log - http://paste.ubuntu.com/10744461/
thread apply all bt would be needed.
Also get me: DISPLAY=:0 vdpauinfo | pastebinit please
A10 is nice beast, can you upgrade the kernel to linux-image-generic-lts-utopic for a test?
oops sorry i forgot the thread apply all bt, here it is
core - http://paste.ubuntu.com/10745215/
vdpauinfo - http://paste.ubuntu.com/10745220/
trying linux-image-generic-lts-utopic to test and report back
thank you again for helping
deep down in mesa. Make a backup and try:
sudo apt-get install mesa-vdpau-drivers-lts-utopic libgl1-mesa-dri-lts-utopic
(I hope that will install a bunch of other mesa packages)
Tried the package installs it seemed to break it completely, going to revert and try upgrading the kernel
kodi last crashlog http://paste.ubuntu.com/10745637/
syslog http://paste.ubuntu.com/10745752/
Please try OpenELEC 5.0.8 from usb stick - slowly it does not get rational anymore.
I reinstalled and upgraded the kernel and now everything seems to be functioning fine. Thank you so much for all your assistance!!!!
