2015-04-06, 04:03
2015-04-07, 01:45
are you using a retina display?
2015-04-07, 03:26
(2015-04-07, 01:45)Memphiz Wrote: [ -> ]are you using a retina display?
Yes I am using a retina display, with Graphics intel Iris 1536MB.
2015-04-07, 10:30
Might be related to that. There are a couple of known issues with retina displays and Kodi which couldn't be solved yet because i don't have a device with retina display. Your best bet is to try to play with the scaling options in osx settings/monitor settings.
2015-04-07, 22:29
(2015-04-07, 10:30)Memphiz Wrote: [ -> ]Might be related to that. There are a couple of known issues with retina displays and Kodi which couldn't be solved yet because i don't have a device with retina display. Your best bet is to try to play with the scaling options in osx settings/monitor settings.
Thanks soo much i tried played around in the scaling option and it fixed it self automatically !! looks perfect now.
Really appreciate your help.
