is there a default volume amplification i can set so that i don't to set it each time for a channel?
+15.0 dB seems the best for me as most channels have very low sound
thx
In the OSD for audio you should be able to increase the amplification, then save for default in all videos.
(2015-04-06, 21:46)PatK Wrote: [ -> ]In the OSD for audio you should be able to increase the amplification, then save for default in all videos.
thx....what is OSD? nm i never seen that set as default for all videos at the bottom of the screen menu ...
In my Audio OSD, the Volume, Volume Amplification and Audio Stream adjustments are greyed out and unavailable to me. It was like this in Helix and now in Isengard. Am I doing something wrong?
You can't adjust volume of passthrough formats (as they wouldn't then be passthrough) so you were probably playing something containing Dolby Digital, DTS or one of the other passthrough formats. To adjust volume for files containing passthrough formats the audio must be decoded to LPCM, to do this you must disable passthrough in Kodi.
Understood. That's exactly what I've been doing. Thanks for the info.
