2015-04-06, 19:24
I am using the WMCserver backend with kodi clients on Rasbperry PI, and other clients with HDHomerun Prime on comcast.
Things work really well. Thank to all for your efforts.
The one thing I do not like are the buttons to fast forward and rewind as they don't work well in my situation.
I would really prefer skip 30 seconds forward and back.
I know you can change that on the keyboard.xml and remote.xml, but is there a way to modify the actual control buttons showing up
when in the GUI ?
We always use the skip 30 seconds forward and 10 back on WMC and would like to emulate that behavior for my
family.
Another button that I use frequently on WMC is the one that allows me to switch back and forth between 2 channels (spacebar on WMC).
I think the "0" (zero) key is supposed to do that as well on kodi, but it would be great to be able to customize and add that to the GUI itself.
Anyway thanks for your help.
when in the GUI ?
family.
